Trans ID help
Old Aug 8, 2018 | 06:56 AM
Rvsmith5's Avatar
Trans ID help
I am trying to investigate my trans more. I was told this trans was a th350. Everything I look up seems to confirm that, but none of my numbers seem to line up with any of the info I read anywhere. Every site mentions letter codes as part of the numbers. I have cleaned and scraped every area numbers are supposed to be. I can only find 3 numbers beyond a single digit anywhere.
Number on tail housing, drivers side.
Number on drivers side behind shift linkage.
Center top, and appears on both sides.
C9. Top front of bell housing
Front driver side of bell housing
Old Aug 8, 2018 | 07:00 AM
How about a photo of the overall trans and specifically the shape of the pan and number of bolts? The VIN derivative indicates that this trans is from a 1977 Oldsmobile, so it could be a TH350 or a TH200.
Old Aug 8, 2018 | 07:05 AM
Rvsmith5's Avatar
Pan is 13 bolts, square with corner cut.
Its not original to the car.
Old Aug 8, 2018 | 07:15 AM
So it's a 1977 TH350.
Old Aug 8, 2018 | 07:24 AM
Rvsmith5's Avatar
Thanks Joe. I guess I was just unsure because I kept reading there should be a letter or 2 in the numbers. Nothing I found seemed to line up with the different charts of numbers I have been able to find. At least you got me far enough to get a new filter and gasket, maybe new pan as this one feels like I could put my finger through it if I tried.
Bob
Zachb92
Dec 24, 2020 11:00 AM
Troys Toy 70
22
Jul 27, 2016 06:05 PM
smash72
Jun 13, 2016 12:39 PM
TexasGunner
16
Aug 12, 2013 07:26 AM
cutty
May 16, 2010 12:31 PM
