Clutch Rod Length
Old Aug 29, 2018 | 09:52 PM
friesjh's Avatar
Clutch Rod Length
Can anyone tell me what the length of the clutch rod from the pedal to the Z-var length is center of pin to center of pin for 71 442 with M22?
Old Aug 31, 2018 | 05:16 AM
friesjh's Avatar
Anyone know where I can get this measurement? I really just need to know which is longer or shorter. Do the older cars, 65-68 or where ever the cutoff is have a longer or shorter rod than the newer, 70-72 cars? I need this rod and the person I am talking to about buying this rod has two lengths, but is not sure which is for my 71. The lengths he has are 14" and 15" rods. Can anyone tell me if my car takes the longer or shorter rod? Then I am seeing longer and shorter rod assemblies for the rod from the Z-bar to the fork as well. Any idea which one I need for this rod?
Old Aug 31, 2018 | 07:07 AM
classicmuscle442's Avatar
Seem like easy solution, buy them both, can't be that expensive.
Old Aug 31, 2018 | 10:53 AM
friesjh's Avatar
Already thought of that, but which one do I use on the car.
Old Sep 1, 2018 | 06:34 PM
Qwik71442's Avatar
Full-time Taxpayer
Here you go...from a 70 14-1/2” center to center
Old Sep 7, 2018 | 05:14 AM
friesjh's Avatar
Perfect, thank you!
Old Sep 7, 2018 | 05:42 AM
VC455's Avatar
Barely Registered
Originally Posted by friesjh
...I am seeing longer and shorter rod assemblies for the rod from the Z-bar to the fork...
The factory clutch uses the shorter rod that, from memory, is around 6.25". Use the 1" longer one on an aftermarket clutch that needs more adjustment.
boese1978
Mar 8, 2016 03:49 PM
craftsman1956
Suspension & Handling
Jul 16, 2010 09:56 PM
Applekrate
Dec 2, 2009 05:57 AM
mb197942
Sep 5, 2008 08:47 AM
