Help! Transmission leak
Old Jul 17, 2018 | 12:36 PM
Green-machine's Avatar
I came out to my garage to find what appears to be transmission fluid and I’m assuming most of it has leaked out of my car. Where do I start guys?!
Old Jul 17, 2018 | 12:39 PM
76olds's Avatar
Hookers under Hood
How much fluid do you think you lost? Overnight ? Any visible trans leaks prior to this?
Old Jul 17, 2018 | 12:43 PM
At least 4 quarts. It leaked a little at the seal and a few months back my line had a plastic piece from what I was told rigged to my lines which melted and stopped my transmission from shifting. Removed that and it has been fine until now
And yes overnight. I drove it yesterday.
Old Jul 17, 2018 | 12:56 PM
It seems to be leaking from somewhere near the rear of the pan and a bracket just behind the pan
Old Jul 17, 2018 | 01:01 PM
76olds's Avatar
Hookers under Hood
I'm thinking a front pump seal or rear seal .
Old Jul 17, 2018 | 02:41 PM
Or the pan gasket.
Or the modulator o-ring.
It's hard to tell from these photos. Frankly, that much fluid didn't come from a seal leak. You'd almost need a leak at one of the cooler lines to pump out that much fluid. Are you cooler lines loose? Are they all metal or do you have hoses?
Old Jul 17, 2018 | 03:45 PM
I was thinking the same. I have hoses according to my mechanic who did previous work on transmission and I don’t know where they connect. Is it something that I can see without getting under it? I only have a jack and don’t really trust that.
Old Jul 17, 2018 | 03:52 PM
The hoses connect on the passenger side of the trans. You will need to lift the car. Get jack stands. At some point, get rid of the hoses and use correct all metal cooler lines.
Old Jul 17, 2018 | 03:53 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Could be the slip yoke or trans tail shaft seal? This is generally exasperated when the car is at a slight angle...nose up which yours is not. Get it up on a lift.
Old Jul 17, 2018 | 04:24 PM
therobski's Avatar
X2 what Joe mentioned. WOW-That's a lot of fluid! If your ride is stock and would like to keep it that way just order new replacement metal lines-plug and play (maybe) I know this is over kill but for about the same $$ spent, I went with braided lines because of all the mods on this build. I wanted to route them for best fit on this application, and it was fun! On the pictures notice that I routed them on top the passenger side fender well. Very clean application however your later A-body plus all the factory parts may not allow this to be easy. But it's darn near bullet proof. I don't like leaks...
Old Jul 17, 2018 | 04:49 PM
Wow, nice setup therobski!! I’m looking for tire cradles as we speak so that I can get under it and get a good look at it. Whatever it is I’m going to take you alls advice on getting the correct or upgraded lines. Thanks for the input guys!
Old Jul 17, 2018 | 05:03 PM
therobski's Avatar
Once you get under the car, I believe Joe is what you will discover. That said Inline tube and others have pre-bent lines for you. That maybe the best and easy way.
Old Jul 17, 2018 | 06:04 PM
I fully expect to walk out to my garage where my Olds is one day and find Joe underneath it.
Old Jul 17, 2018 | 06:21 PM
About the only thing that could leak that much overnight and be fine while driving would be the o-ring around the modulator or around the dipstick tube. When the car sits overnight and the torque converter drains back into the pan the fluid level raises above the level of those seals. Clean the old fluid from under and around the car, add just a little A/C oil with the florescent dye, drive the car for a while, then crawl under it with a black light. The dye will highlight exactly where the leak is.
I agree with Joe, rubber hose has no place in a transmission line!! Unless the steel line has a bead or something for the hose clamp to grip, eventually that hose will slip off the line, spraying ATF all over the hot exhaus. Bite the bullet, drop the transmission pan, replace the o-ring on the modulator and dipstick tube, install new steel lines, and replace and refill the fluid.
Old Jul 18, 2018 | 05:56 AM
therobski's Avatar
Me too:I fully expect to walk out to my garage where my Olds is one day and find Joe underneath it.
Old Jul 18, 2018 | 04:46 PM
Old Jul 18, 2018 | 04:48 PM
Matt, thanks for the advice. I’ll try to figure out where it’s coming from tomorrow and give everyone an update. I’ll definitely change those lines for sure.
Old Jul 18, 2018 | 04:53 PM
76olds's Avatar
Hookers under Hood
I hope its something as simple as your lines. As mentioned above Inline Tube is a good place for pre-bent lines.
Eric
Old Jul 18, 2018 | 05:00 PM
76olds's Avatar
Hookers under Hood
Or the pan gasket.
Quite a bit of seepage by the modulator ( easy taking the bolt out, the ear usually breaks off then you need a bracket to hold the modulator in place) but a line leak sounds more like the problem.
I would put a few seals on the repair list as well if it were me.
All the best with the repair !
Eric
2blu442
Mar 20, 2019 01:34 PM
72455
Dec 25, 2018 01:22 PM
Christopher Michael Drew
Dec 17, 2018 11:47 AM
Cosmic Charlie
Nov 25, 2018 04:08 PM
tdhill01
Oct 9, 2018 11:00 AM
