Bowtie Overdrives 200-4R
Old Mar 26, 2018 | 04:43 PM
travisbeamon's Avatar
Greetings,
I currently have a 1972 Cutlass Supreme with a 350 Rocket that has been beefed up slightly and pushing just over 360 hp. I just installed a 10 Bolt posi with 3.42 gears and I'm now looking for an OD transmission. I've been looking at Bowtie Overdrives 200-4R level two and would like any feedback that can be provided on the vendor, transmission selection, etc. Thank you!
Old Mar 28, 2018 | 09:21 AM
oddball's Avatar
Bowtie's quality can be hit or miss, but they are cheaper. I installed one in a buddy's Chevelle, it works OK. Calibration isn't quite right, but runs fine. Some of their add-on parts were junk (speedo adapter, lockup system).
I had Extreme Automatics build one for my Cutlass. Had to send the governor back for adjustment but it runs great. Quite a bit more expensive.
There's a few other small shops that still do 200-4rs, but they're getting scarce. CK Automatics is the parts supplier for a bunch of the common upgrade parts and they still build them to order.
A good converter and lockup scheme is a big part of the equation. PATC has some good options. I had a small shop build mine - R&R Racing Torque Converters - and its a great match and at a good price. I wanted Lenny @ UCC to build one - the th350 converter he built was awesome - but his price was more than 2x R&Rs. Lenny doesn't like building lockup converters.....
Note that any built 200-4r will "bang" going from 3rd to 2nd. It's a feature to keep parts from getting destroyed. If you like quiet comfy shifts then this is not the trans for you. The shifts have to get moderate to hard or else the trans eats itself.
Old Mar 30, 2018 | 10:18 PM
olds403's Avatar
Dave Husek.....
Old Mar 31, 2018 | 01:50 AM
I ended up purchasing a Stage 1 200-4R from Extreme Automatics.
Old Apr 4, 2018 | 06:31 PM
TexasT's Avatar
Originally Posted by olds403
dave husek.....
x2
Old Apr 5, 2018 | 05:59 PM
Sampson's Avatar
I have a similar Hp 350 setup and I used Extreame Automatics. I could not be happier. Car has about 15k miles on it now with no issues. I followed his directions on TV cable adjustment and pressure setting when I installed it. Also followed his recommendation on the deep sump pan. Shifted correctly right from the git go and I have not touched it since.
Olds64
Jul 18, 2016 08:19 AM
Gre975
Jul 13, 2016 04:04 PM
ezman604
Dec 18, 2015 06:04 AM
Olds64
Jan 29, 2008 06:17 AM
J-(Chicago)
Drivetrain/Differentials
Dec 11, 2007 07:08 PM
