need some transmission cooling lines
Old Mar 29, 2010 | 11:59 AM
1973olds98's Avatar
Pulling my engine i messed up the cooling lines and I need some replacement..I figured it would be something i could get from autozone but i was wrong,,Any help would be awesome,,thanks
Old Mar 29, 2010 | 12:49 PM
blueRAYwhale's Avatar
:)" Trans. cooling lines"
I think the dimension from the front of the trans. bell-housing to the back of the radiator(3-core/4-core), is the same on 1976 Cutlass's as it is on 73's. If so then you can use the TH350/TH400 lines as they are interchangeable. I also think Delta 88/98 cars will work too.
Old Mar 29, 2010 | 01:40 PM
70 cutlass s's Avatar
Easiest way is just bay the size line you need and bend it. Which you can buy a strait line at a local auto parts store the bending tools is around 10 bucks.
Old Mar 29, 2010 | 01:55 PM
X2. Just get the correct size brake line from your favorite auto parts store and bend them to match the original lines. Unless you care about complete originality, this is not particularly difficult. If you DO care about originality, the usual vendors of pre-bent brake lines also sell the cooling lines.
Old Mar 29, 2010 | 05:36 PM
MJAKS462's Avatar
I may have some decent lines here . 350 engine 350 trans , automatic.from a 72 Supreme
I would think that they would clean up easy. PM me.
Stevec
Apr 18, 2012 06:44 PM
ragtop442
Apr 6, 2011 04:52 AM
mhartley
Jan 24, 2011 08:02 AM
misercola
18
May 3, 2010 03:39 AM
erke88
Apr 19, 2010 11:51 PM
