1955 Hydra-Matic question
Old Jul 26, 2016 | 03:37 AM
Fenian16's Avatar
Hello All
Please forgive me if this is a dumb question; transmissions are definitely not my forte. Does anyone know if the slant pan type Hydra-Matic from a 1955 Pontiac is the same trans that was used in the 1955 Olds? Any info would be appreciated.
Dan
Old Jul 26, 2016 | 06:50 AM
Tedd Thompson's Avatar
This is just a poorly educated guess but I would think the bell housings would be different, same transmission other wise, not a direct bolt up.... Tedd
Old Jul 26, 2016 | 08:00 AM
59-59-59's Avatar
According to the flat rate/parts manual, it looks like it's somewhat identical, with part numbers being the same, except front planet carrier, drum, rear planet carrier, and some other small parts. Even the transmission case interchanges.
Old Jul 26, 2016 | 06:56 PM
Fenian16's Avatar
Thanks for the info guys.
Dan
Old Jul 28, 2016 | 06:42 PM
Ozzie's Avatar
Hollander shows different numbers for the flywheel and torus units; also different for the "identical" transmission units. My Hydra-matic service manual shows the '55 Pontiac as a model 55-P and the '55 Oldsmobile as a model 55-R. So, as has been said, some things are different.
doc93
Nov 5, 2023 05:13 PM
BenJammin
19
Apr 19, 2016 09:06 AM
BenJammin
Jan 7, 2014 11:55 AM
cook67
Jun 11, 2012 02:33 AM
American Lead
Nov 16, 2008 04:10 PM
