Transmission trouble
Hello ,
My jetstar 1 transmission slips.
When ik looked under the car transmission fluid is leaking.
It's leaking from the cover with the 2 bolts in front of the transmission underneath the engine.
I'm not sure but what must i find when i take of that cover transmission fluid or not ???.
And the transmission in my car is that a hydra matic ???
Greetings Barry
Greetings Barry
Hello America,
I found out in my manuals that it is the flywheel cover.
There is no atf fluid behind it.
I filled the atf fluid to the correct height .
Now when i drive the car and the atf fluid warms up the transmission is slipping in al ranges.
What could be the problem.
I found out that there must be a serial number on a colored plate on the transmission.
I only have the square where the plate was.
So i think it's still in america some where.
So how can ik figure out what kind of transmission is have.
Greetings from Holland.
misercola
18
May 3, 2010 03:39 AM
