Speedometer cable question
Old Aug 20, 2017 | 03:41 PM
Blair's Avatar
I'm hoping to change the gear in my transmission so that I can synchronize the rear end with the speedometer. My transmission is a THM350 and my gear is a 3.42 Richmond gears limited slip differential. Can anyone give me an idea of what gear I need? It's for a 73 Olds Cutlass . Thanks!!
Old Aug 20, 2017 | 04:16 PM
Happy Trails's Avatar
This thread has some good info with links to online calculators that can help answer your question. You'll need to know your axle ratio (3.42 in your case), tire size, and how many teeth in your drive gear. Probably best to check the drive gear and not assume which one it is.
The Flash
Ninety-Eight
Jun 12, 2015 08:52 AM
Nighthawk
Jul 27, 2013 09:49 AM
wolfman98
Nov 18, 2009 05:06 AM
Pfiffle
Drivetrain/Differentials
Mar 13, 2008 11:22 AM
ct1979
Dec 21, 2006 03:08 PM
