Trans adaptor 1957
Old Jun 26, 2017 | 11:22 AM
supmarjo's Avatar
Trans adaptor 1957
hi i been looking on line ,to convert my hydromatic jetaway...and found this guy up in Sacramento Tanson Ent. anyone have work from him?
Wilcap dose not make his kit for the 1957 olds anymore.
Bendsten's Transmission Adapters... web page dose not open
the hydro i have is working, but looking to have an overdrive option..700r or?
Old Jun 27, 2017 | 10:27 AM
d2_willys's Avatar
Try Tony Ross (goatroper) @ Ross Racing. He specializes on adapting Olds Rockets to newer transmissions.
Old Jun 27, 2017 | 04:59 PM
Charlie Jones's Avatar
Phantom Phixer
http://rossracingengines.com/c/11/ol...early-catalog/
It' best to call him , websight is sketchy , products are not .
I think he may be doing 700R trans now .
330-544-4466
BTW , his name is Tony Lombardi .
Old Jun 28, 2017 | 04:32 PM
Tedd Thompson's Avatar
Good man, great products and a little expensive but the quality is there.
Tanson is not to far from me and I have heard the name for years but I personally don't know the quality of his work, Tony on the other hand is a Oldsmobile guy and knows his stuff. Let us know how everything works out.... Tedd
Old Jun 30, 2017 | 11:25 AM
supmarjo's Avatar
thnks..... sent him an email.
web page dose not have much info...
going on a 4 hr road trip soon..good chance to get a good MPH readings .
happy 4th
Old Aug 11, 2017 | 09:03 AM
supmarjo's Avatar
ok, i got 10mpg.;O .dose that sound close to the mpg OLDSMOBILE came up w back in 1957.
talked to TONY, and after adding up the cost,he’s 25 percent higher...but all in one place and a very good reputation. could be a winter project.
Old Aug 11, 2017 | 10:45 AM
59-59-59's Avatar
This is one of the times I said screw the cost. Tony's kit is the best and most complete out there - the billet flywheel he supplied belongs in a museum, workmanship of the transmission case is second to none, and the real time saver is the optional mounting bolts that uses the stock transmission mounts.
Old Aug 12, 2017 | 06:34 AM
Rocketowner's Avatar
Cannot say about a '57 but my '55 would get a consistent 16/17 mpg on a highway run,and did so after I installed aftermarket air conditioner. Larry
Old Aug 12, 2017 | 09:45 PM
My 55 on numerous long road trips averaged 13-14 MPG, some city driving but mostly good back roads and often at 65-75 MPH.It ain't a VW rabbit.... Tedd
Old Aug 13, 2017 | 08:11 AM
Phantom Phixer
10 MPG does seem low . These cars usually got 13 to 18 MPG back in the day .
IF , the driver didn't have a "heavy foot" . Do you often enjoy the power and torque of this beast ? Be prepared to pay the price for it at the pump .
Another thing , the gas of today usually contains 10 or more percent ethanol .
Ethanol has less heat content per gallon , so it lowers fuel mileage some .
Also is your engine in proper tune ? New plugs and points ? Air filter new or clean ? Good compression ?
As far as swapping in an overdrive transmission , yes you will save a few miles per gallon.
However , at what cost ? The cost of a trans conversion , that I have seen , is anywhere from $1800 to $2500 . That money buys a lot of gas .
If the car were a daily driver , then maybe you will get your money back in gas savings eventually . If the the car is only used occasionally , as most "hobby" cars are , and the present transmission is in good repair . Then the best choice may be to simply buy the gas , and leave things alone .
Old Aug 14, 2017 | 09:20 AM
supmarjo's Avatar
thnks for the info ... as far as tune up ,yes plugs,wires,points,carb kit(2g)
the small air cleaner might change. It seams to get dirty fast....15 mpg would be great!
I have been having a big foot .
CJ ... interesting way of looking at things(mpg) Thnks
Old Aug 14, 2017 | 11:07 AM
Phantom Phixer
If I read this right , you spent $2000 on a tune-up and a carb rebuild ?
Too bad you aren't in central Florida . I would have done that job for a quarter of that . And still made money .
You're on the right track though . Now you need to practice driving with an egg between the gas pedal and your foot . (start with a boiled one )
Old Aug 14, 2017 | 11:53 AM
supmarjo's Avatar
no no... tune up cost was a few hundred...i see the mix up , 2g ..is the 2 barrel carb kit
this made me laugh
. (start with a boiled one ) thanks
Old Aug 14, 2017 | 02:19 PM
Just pay the price and grit your teeth, you only live once. Besides the first thing people ask me is it still original?.... Tedd
Old Aug 14, 2017 | 06:09 PM
Phantom Phixer
Sounds to me like you have a "castrated " J-2 .
1957 was the one year that Oldsmobile did not offer a 2 bbl. carb .
Instead , the four barrel was standard , and the "J-2" setup of three two barrels was offered optionally .
The biggest problem with the J-2s was that many owners did not drive with their "foot in it " enough to get fresh gas in the end carbs . This led to problems like leaking needle and seats . Which flooded the engine .
Many mechanics solved this problem by simply removing the front and rear carbs . And blocking, off the holes with a small steel plate .
Oldsmobile did just that from the factory , in 1958 . That was in a "recession" year that they hastily introduced their low priced "Dynamic 88 "
GTC
35
Jul 29, 2021 05:17 PM
Charly9g
Oct 4, 2014 12:15 PM
1971
Oct 18, 2011 08:42 AM
yeahbuddy
Jan 17, 2011 11:20 AM
StickW31
Jan 21, 2010 08:11 AM
