Seal removal Tool
Old Jul 26, 2019 | 08:35 PM
Gary's 2 442-S's Avatar
Gary
Seal removal Tool
I need to replace the seal on the shift shaft on my 400 transmission. What tool are you gentleman using? Before I order this one is there any other suggestions.
https://www.napaonline.com/en/p/BK_7769250
Old Jul 27, 2019 | 05:23 PM
I have that tool, it works well. Make sure you file off the burr that forms where the shifter cable bracket bottoms on the shaft. Run your fingers over the squared off shoulder, if you can feel a lip it will cut the seal.
Old Jul 27, 2019 | 05:58 PM
Gary
Thanks Matt for that information.
Old Aug 6, 2019 | 12:24 AM
AMT Transmissions's Avatar
Tare passion
Seal tool
If you don't want the tool, take a decent pick 2 sided and Grind the staight pic on both side. You'll have a small rectangular shape pic. Pull or cut other end off. Stick it into rubber part of seal and pry at 45 degree angle. Careful not to scrap or scratch the shifter shaft. Pound new seal in with socket.
Oldssupreme
Aug 3, 2016 06:12 PM
jensenracing77
May 25, 2016 05:27 AM
Supernaut72
May 9, 2016 12:38 PM
RROLDSX
Mar 17, 2014 02:29 PM
dynamic88
Aug 28, 2007 11:03 AM
