TH350 Help
Old Jun 7, 2020 | 02:41 PM
miller6323's Avatar
TH350 Help
hi all,
I have an 80 cutlass supreme with a stock turbo 350. It drives great but the shift points are really high. Idk what the rpms are as I dont have a tach but its wound up tight. I also have a really hard time getting the fluid levels right in the tranny as well. It jumps from the bottom of the fill line to 2 inches above with just 4 ounces. Ive changed the modulator and have pulled the pan and replaced the filter. Any help is appreciated.
Old Jun 7, 2020 | 04:17 PM
nicks1966's Avatar
Have you pulled the governor to make sure it not sticking and that it gear is not broken?
Old Jun 7, 2020 | 04:25 PM
miller6323's Avatar
I haven't pulled the governor yet. It could be sticking i suppose. If I shift it manually then it'll work but it has some hesitation still.
Old Jun 7, 2020 | 05:48 PM
James W. Frey's Avatar
Hi, welcome to the group!
Make sure you are getting good vacuum down to the transmission. Do a search on this forum for more details, like this one:
https://classicoldsmobile.com/forums...-cutlass-4534/
a wealth of great information here!
As for the fluid levels, are you checking with the engine running and at operating temperature? Take it for a quick drive to warm it up and cycle through the gears (including reverse), then park it and leave it running. At this point this is the best condition to check the fluid, should be right at the full mark.
hope this helps,
james
Old Jun 7, 2020 | 06:50 PM
pav8427's Avatar
Some modulators have adjustment for shift firmness. All it takes is a small screw driver into nipple the vacuum line hooks to. Clockwise should firm them up. Dont go to far though can be damaging.
Old Jun 7, 2020 | 09:12 PM
Originally Posted by miller6323
hi all,
Are you referring to full throttle shift points or "normal" driving low RPM / low speed shift points?
Old Jun 7, 2020 | 09:13 PM
miller6323's Avatar
Normal driving. Most of the time it won't shift at all unless its wound up. But then other times it works like its supposed to.
Old Jun 7, 2020 | 09:17 PM
That sounds like it may be a vacuum modulator issue. Have you verified the vacuum hose connection from the modulator to the intake manifold, and verified there is a strong vacuum signal on the hose at idle?
Old Jun 7, 2020 | 09:19 PM
miller6323's Avatar
I have checked the vacuum where the hose connects on the carb and its between 15 and 20. I havent checked it at the bottom where it goes into the modulator.
Old Jun 7, 2020 | 10:05 PM
Check it at the bottom
Old Jun 8, 2020 | 07:48 AM
Make sure the vacuum line is metal. I have seen many times over the years where people have used rubber hose the entire length. Add a few years of oil and grime, plus heat from the exhaust, and the vacuum hose can get sucked closed. No vacuum at the modulator=late or delayed shifts.
Old Jun 8, 2020 | 09:41 AM
miller6323's Avatar
Its metal. I haven't checked it for pinholes yet though.
Old Jun 11, 2020 | 03:53 AM
miller6323's Avatar
Ended up finding a small pinhole in the metal line. Can anyone confidently tell me which way turning the modulator does what and about what increments I should adjust it?
Old Jun 11, 2020 | 04:54 AM
Lonnies Performance's Avatar
Clockwise raises & firms the shifts. Go about 1/4 turn at a time & test drive.
Keep in mind it only effects part throttle, WOT will still be the same.
brown7373
May 7, 2018 07:59 PM
hookem horns
Jan 29, 2015 10:53 AM
69'442
20
Oct 18, 2013 04:38 PM
CutlassLegend
Aug 12, 2011 09:07 AM
mike623
Sep 7, 2010 09:48 AM
