TH350 Help
TH350 Help
hi all,
I have an 80 cutlass supreme with a stock turbo 350. It drives great but the shift points are really high. Idk what the rpms are as I dont have a tach but its wound up tight. I also have a really hard time getting the fluid levels right in the tranny as well. It jumps from the bottom of the fill line to 2 inches above with just 4 ounces. Ive changed the modulator and have pulled the pan and replaced the filter. Any help is appreciated.
Hi, welcome to the group!
Make sure you are getting good vacuum down to the transmission. Do a search on this forum for more details, like this one:
https://classicoldsmobile.com/forums...-cutlass-4534/
a wealth of great information here!
As for the fluid levels, are you checking with the engine running and at operating temperature? Take it for a quick drive to warm it up and cycle through the gears (including reverse), then park it and leave it running. At this point this is the best condition to check the fluid, should be right at the full mark.
hope this helps,
james
hope this helps,
james
That sounds like it may be a vacuum modulator issue. Have you verified the vacuum hose connection from the modulator to the intake manifold, and verified there is a strong vacuum signal on the hose at idle?
Make sure the vacuum line is metal. I have seen many times over the years where people have used rubber hose the entire length. Add a few years of oil and grime, plus heat from the exhaust, and the vacuum hose can get sucked closed. No vacuum at the modulator=late or delayed shifts.
