Why would my 69 442 slip slightly in first
Old May 24, 2008 | 05:11 PM
IDAS 69's Avatar
Question Why would my 69 442 slip slightly in first
Why would my 69 442 slip slightly in first. Just doesn't get off the line like I think it should. Any help would be appreciated... Thanks Eddie
Old May 25, 2008 | 08:11 AM
don71's Avatar
same but different
Slipping in gear could point to low fluid level. I'm sure you checked that, which leads me to say its an internal problem $. Perhaps its a linkage/shifter cable issue.........check to see that it correctly moves and not stuck inbetween selected ranges.
Old May 25, 2008 | 10:45 AM
IDAS 69's Avatar
thanks don,
fluid level okay. when starting for a dead stop. it just feels like trans is slipping. when it hits 2nd..it's okay. someone also said to check all vac hoses for leaks... could this also be the cause? eddie
Old May 26, 2008 | 08:27 AM
Bluevista's Avatar
Registered
Have the transmission filter and fluid been replaced lately? A real dirty filter can cause problems like that sometimes I've heard.
Allan
Old May 26, 2008 | 06:37 PM
IDAS 69's Avatar
FLUID BUT NOT FILTER..I'LL TRY THANKS AMH
Old Jul 27, 2008 | 07:21 AM
southcarolina803's Avatar
71'OldsCutty
i had the same problem did u figure out what it was? im tuning the tranny today
Old Sep 9, 2008 | 07:41 AM
IDAS 69's Avatar
Yeah, I figured out what was wrong. Actually transmission guy told me....Broken pieces of clutch in pan......... Doing a soft rebuild....$650-$750..Question???? What is a "soft" rebuild? Thanks
Old Sep 9, 2008 | 10:34 AM
I believe it is a transmission rebuild where the technician replaces all of the "soft" parts in the transmission. This would include gaskets, seals, o-rings, and hopefully fiber AND steel clutches and bands. This would be pretty standard for an automatic transmission since it hopefully doesn't need any "hard" parts (i.e. pump, sun and planetary gear set, output shaft, etc.)
jag1886
Mar 17, 2018 12:12 PM
CarCrazyChemist
Jun 4, 2014 07:09 PM
brown7373
Oct 6, 2011 01:54 PM
Joffroi
Nov 22, 2010 02:41 PM
1BAD68"S"
Nov 9, 2006 04:30 AM
