Transmissioin coolant lines
According to my 70 service manual, the feed from the transmission first enters the radiator cooler at the bottom port, and then returns to the transmission from the top port. If an additional air cooler is used, it is placed downstream of the radiator cooler and it is fed from the top port of the radiator cooler. From the air cooler the fluid then returns to the transmission.
Arrowstorm
Feb 9, 2007 02:30 PM
