82 cutlass pouring transmission fluid out of front seal
Old Dec 5, 2015 | 05:00 PM
82cutlass's Avatar
My 82 cutlass is pouring trans fluid out when u fill it up replaced front and rear seal and filter no change doesn't leak until started and just pours fluid out pump starts whining and pours fluid any ideas. Just bought it has been sitting for 11 years it's olds th350
Old Dec 7, 2015 | 07:22 AM
88 Cutty Classic's Avatar
maybe the torque converter?
Old Dec 7, 2015 | 09:14 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Tad more info and some punctuation in the post helps us sort things out easier such as periods(not being condescending, trying to help).
Where does it leak? What trans model? Stock or Modified trans? Did you do the seals or have it done? Did you install the converter? Do you know the dos and donts when installing a converter?
Old Dec 7, 2015 | 09:47 AM
Octania's Avatar
Are you sure it's not coming out the fill tube seal to trans?
That seems more common to me than a gusher at the front seal.
Those typically leak a little and drip.
PS note how easy reading is with a <CR> or two to generate white space. It's free. Use all you want.
Jannebill
Mar 1, 2015 05:52 PM
EightyEightCut
Feb 9, 2013 07:51 PM
Swoopy
Oct 18, 2010 08:55 PM
cfair
Brakes/Hydraulic Systems
Jun 8, 2009 12:37 AM
projectheaven
Apr 27, 2008 07:08 PM
