4L80E in a 65 Olds 98
Old Oct 5, 2015 | 02:32 PM
darksider415's Avatar
I'm going to bounce this off of anyone here, to see if anyone has done a 4L80E swap with aftermarket controller in a 98, and if anyone has run into any clearance issues.
I know the length from the bellhousing to the mount is off by 1 11/16" from the TH400 to the 4L80, but I don't know which tailshaft variant we have, so I don't know the difference in overall length, yet.
I'm wanting to do the OD swap, because my long-term goal for my car is to be a good, solid, mostly-stock driver that will get okay gas mileage on long trips, and I think the OD will go a long way to doing that, while cruising at interstate speeds.
Any suggestions?
Old Oct 5, 2015 | 04:14 PM
Any suggestions?
Your car came with the "long" tailshaft TH400, however this is actually the mamma bear middle tailshaft. The really long pappa bear tailshafts were used on trucks. Your problem with the 4L80E fitment isn't overall length (you'll need a custom driveshaft anyway). The problem is that the case is much larger in diameter for longer than the TH400. This is because the 4L80E basically takes the TH400 internal parts, moves them backwards, and puts an O.D. gear set and clutch pack between them and the converter. Slide your TH400 about six inches back and see how it fits. Yeah, I realize that's not a good comparison because the bellhousing would hit the firewall, but you get the idea.
Old Oct 5, 2015 | 07:10 PM
cherokeepeople's Avatar
i will agree.i have one laying on my floor right now and a th400 looks like a powerglide next to it.
Old Oct 8, 2015 | 10:37 AM
d2_willys's Avatar
Aren't the 4l60 and 4l80 transmissions meant for Chevy engines? I thought the BOP pattern is long gone!
Old Oct 8, 2015 | 03:23 PM
all it takes is an adapter plate
Old Oct 9, 2015 | 10:11 AM
Charly9g
Jun 28, 2015 11:23 AM
csouth
Mar 27, 2014 06:04 AM
quentinnw2
Nov 15, 2013 09:13 AM
Nasty455
May 15, 2012 08:01 PM
MLK-442
Oct 28, 2011 04:26 PM
