6speed manual for a 455 rocket?
I have a TKO-600 5 speed in my '68 442, THE BEST upgrade I ever made. Shifts like butter, and the overdrive helps with the MPG. (You can get overdrive in either .64 or .82 to one, whichever you prefer with your rear gears.) Bolts to stock bellhousing,but have to cut the trans tunnel for clearance. Top shifter as well, no missed shifts from shifter linkage problems.
Not cheap, $2500+ ,but well worth it IMO.
Greg
Greg
You might want to take a look at KieslerAuto.com. I was just reading about their new line of RS transmissions that are supposed to fit GM A bodies without any modifications (no cutting, use existing crossmember, stock shifter location, etc.). I don't want to have to extensively modify my car, so these look interesting to me. They have three versions with the top version rated for 600 ft. lbs. In additiion, the 600 ft. lb version has better ratios for a big block, in my opinion. They have some videos on KieslerTV.com that are pretty good. They just did a conversion in a 70 GTO and it looks pretty slick.
Boldsmobile
Dec 13, 2015 07:16 PM
Boldsmobile
Jan 22, 2011 01:26 PM
