68 2 Speed Auto rebuild kit?
Old Jun 27, 2011 | 08:26 AM
Joffroi's Avatar
Runner
Question 68 2 Speed Auto rebuild kit?
My transmission is jumping quite a bit and I think since its numbers matching I'm just going to go the rebuild route.
Where is the best place to get parts for a 1968 2 speed automatic powerglide transmission rebuild kit? I tried googling around but figured you guys were the best resources :-)
Old Jun 27, 2011 | 08:40 AM
Tony72Cutlass'S''s Avatar
Check out http://www.bulkpart.com/Merchant2/me...General-Motors
I've seen a couple posts on here that referenced this website, i'm thinking of rebuilding my TH-350 in my cutlass and might be buying a kit from here.
Any other opinions on Bulkpart.com?
Cheers,
Tony
Old Jun 27, 2011 | 10:04 AM
Olds Dad's Avatar
Collector of Stray 55's
www.autotran.us
Old Jun 27, 2011 | 11:12 AM
First of all, your trans is NOT a Powerglide. It's a Super Turbine 300. Olds never used the Powerglide trans. The two have nothing in common other than being two speed automatics. You can get parts from Fatsco:
http://www.fatsco.com/
Old Jun 27, 2011 | 11:15 AM
Olds Dad's Avatar
exactly why I recommended autotran...they specifically list the s/t 300 vs the powerglide...
Old Jun 27, 2011 | 11:30 AM
Joffroi's Avatar
Runner
What would I do without you guys.... Thanks for the information. I'm trying to remember where I first heard powerglide when I was doing all this.
What is the easiest way to check which transmission I have in there. Where is the casting number? I might as well see if it is numbers matching as described.
Old Jul 2, 2011 | 02:51 PM
jag1886's Avatar
Are you going to rebuild this transmission yourself? If not let the transmission shop find the parts, they probably won't guaranty the rebuild with carry it parts.
O's_Car
Jun 19, 2023 07:40 AM
ignachuck
Jun 12, 2015 05:29 PM
dedsleds
Feb 28, 2012 03:02 PM
HIGHCOMP425
Dec 20, 2011 07:19 PM
vista461
Aug 8, 2009 12:16 PM
