67 Olds kickdown switch electrical tabs?
Old Oct 19, 2011 | 09:50 AM
Sid's Avatar
Sid
Question 67 Olds kickdown switch electrical tabs?
I have installed a n.o.s Trans Kickdown switch for my 67 Cutlass and there are three electrical hook ups one for the Batt. and one on the horizontal and one on the vertical when looking at the switch, I know one is for the switch pitch converter and the other is for the trans kickdown. I need to know what one of the two tabs is for the kickdown. The turbo 400 I have installed does not use the switch pitch and has only one tab for electrical hook up.
Thanks ------------SID
Old Oct 19, 2011 | 10:07 AM
You have 12v going in from one plug, and another plug with 2 wires in it. I believe its the vertical tab, but to be sure put a meter on it and see if you have 12v when the throttle is depressed.
For the kickdown just take put 12v on one side of the switch, and run a wire from the other side to the transmission.
If you don't mind what kind of switch and bracket are you using. I'm fixing to do the same to mine! Pic's??
Old Oct 19, 2011 | 07:23 PM
67KS442ORIG's Avatar
Other pictures I have seen of this switch are a round variety.
For what it's worth, this is my original install.
The wire colors may help.
Bill
Old Oct 20, 2011 | 08:49 AM
I misread your post!!! Ok the single wire and plug is your 12v. The double wire and plug is for your kickdown and switch pitch signal. Take a voltmeter to the two terminals on the switch housing and see which one supplies power @ wot only, I believe its the top one! I would have to look when I get home for wire colors!
Look at this post:
https://classicoldsmobile.com/forums...er-switch.html
Old Oct 21, 2011 | 06:18 AM
Sid's Avatar
Sid
Thanks for all your help.
SID
Old Oct 24, 2011 | 08:45 AM
Sid's Avatar
Sid
Question 67 Olds KIcktown switch
I installed the new N.O.S Delco kickdown switch the way it is discribed in the Olds service manual and my kickdown still will not work. There is 12 volts power to the switch and the switch pitch tab has power but not the trans kickdown. I find it hard to belive the new switch is bad any Ideas on what could be wrong or is there something I am not doing right to set the switch?
SID
Last edited by Sid; Oct 24, 2011 at 08:47 AM. Reason: Should say New 67 Olds Kickdown switch
Old Oct 24, 2011 | 11:03 AM
Is you linkage operating as such to allow the kickdown to activate at full wot??
arodenhiser
May 22, 2017 05:39 PM
Solid Lifters
Aug 6, 2013 06:29 PM
nelsontj
Jul 20, 2010 12:08 AM
esisson
Jan 2, 2009 09:27 AM
Ducman
Nov 14, 2007 12:34 PM
