Bottom Radiator Tabs Installation
Old Jul 5, 2010 | 11:50 AM
nelsontj's Avatar
I want put a radiator shroud on a 1970 Olds 442 which did not come factory on this car. Do the bottom tabs that hold the lower part of the shroud get bolted on or are they supposed to be spot welded on? I got tabs from one of the major vendors and it looks like they are supposed to be bolted on. If so, where, or what, do they get bolted onto?
Old Jul 20, 2010 | 12:08 AM
Jonb442's Avatar
Hi,
The tabs/brackets which locate the bottom of the shroud are welded to the radiator support. There should be tabs there for the shroud used with a 3-core radiator, which have to be cut down and some material removed to fit the taller brackets for a 4-core radiator shroud. I just switched mine over from my rotted original 4-core support to a replacement 3-core support. I can e-mail or post some pics if you like.
-Jon
lvelocci
Body work
Nov 15, 2010 11:05 AM
lvelocci
Body work
Nov 14, 2010 06:06 AM
tdubis
Nov 20, 2008 03:39 PM
Ducman
Nov 14, 2007 12:34 PM
muddy
Jun 10, 2006 04:24 AM
