425 turbo
Old Jun 6, 2011 | 05:19 PM
georgep's Avatar
425 turbo
Can a 400 series short output shaft be exchanged for the output shaft in a 425 series trans ? I am aware that an adapter will be needed to mate the housing and a place for the fill tube will need to be fabed. Plans are to use the trans for a mid-engined car but I need to move the weight forward as if left as is there will be too much weight behind the center line of the axle. Any info from those more knowledgeable would be appreciated
Old Jun 7, 2011 | 06:29 AM
Other folks have turned the Toro drivetrain around (engine facing rearward) then split the differential from the trans case. You can move the engine/trans assembly forward then build an adapter and driveshaft to go between the trans output shaft and the differential case. Of course, you'll need to flip the differential so the car runs in the right direction.
matviar
Feb 26, 2012 11:05 AM
80_cutlass
Mar 17, 2011 06:03 PM
Liegekiller
15
Jun 27, 2009 07:58 PM
Liegekiller
May 30, 2009 05:31 PM
