Question about a Dual gate shifter
Old Jun 13, 2012 | 09:18 AM
Doomah's Avatar
so a friend of mine heard i wanted a dual gate shifter for my car, he went out and got one from a 1969 GTO. My question is am i able to install this in my car I am a column shifter right now and wanted to switch to center console. I have looked on line and found some people saying it is the same but when I look at pictures of the 69 GTO it looks different then the 69 cutlass one. I also have one other question the shifter came with the mounting brackets but no linkage, do I need to get a neutral safety linkage? Plus can I get a 69 cutlass center console and put this in it? if picture will help i can post them.
I am installing a TH350 so the shifter will get connected to it. Any help would be great.
Old Jun 13, 2012 | 10:00 AM
rocketraider's Avatar
Oldsdruid
You need to remember that Pontiac offered the Dual/Gate (His-n-Hers in Pontiac-speak) as a RPO starting 1966. Olds offered it as part of the 68-69 Hurst/Olds package and it was a standard-issue Hurst Dual/Gate adapted to the Hurst/Olds' mini-console, since Hurst/Olds were technically aftermarket conversions. Hurst designed Pontiac's specifically to work with the GTO's full-length console and Olds didn't get that luxury until 1970.
I think a 70-72 Olds D/G with console will bolt into your car easier than the 69 Pontiac unit, but you can make it work with some effort. You need the neutral start stuff and probably a specific D/G shift cable to pull it off.
Also consider 1969 Cutlass was still using the shorty console for automatic floorshift cars. IDK if a Dual/Gate will work in one of those or not.
Old Jun 13, 2012 | 10:07 AM
Gator69olds's Avatar
Pic of the shifter and and the mini console
In a '69 H/O
Old Jun 13, 2012 | 11:41 AM
Eddie Hansen's Avatar
another thought...
PJ,
if you are not THAT worried about originality a 69 gto console will also fit in your car with no problems. I know you currently dont have a console, it would look like it belong albeit not exactly correct.
I think the dual gate is AWESOME!!!
Old Jun 13, 2012 | 12:20 PM
Doomah's Avatar
I am fine that it will not be original, just want to make sure my friend didn't waste his money and I want to install the Dual gate :P
Old Jun 13, 2012 | 12:23 PM
Doomah's Avatar
NEUTRAL SAFETY SWITCHES
I see the parts place has it was wondering if I need to buy this?
Old Jun 13, 2012 | 08:06 PM
Oldsdruid
Yeah, that would work, but god help, them Pontiac guys want your firstborn for a GTO D/G console!
jensenracing77
May 6, 2011 04:21 PM
GAOldsman
Apr 28, 2011 08:01 PM
Beob
Mar 1, 2011 07:51 PM
69442
Hurst/Olds
Nov 27, 2010 09:02 PM
