Aurora V8 conversion
Old Aug 2, 2012 | 04:59 PM
therobski's Avatar
Is there any GM rear wheel drive automatic transmission that will bolt to the Aurora V8? Also if so will it work on the Northstar?
Old Aug 2, 2012 | 06:37 PM
CRUZN 66's Avatar
Olds Fever
Oldsmobile built a one only Street Rod using the Aurora V8 that was rear wheel drive, but I couldn't tell what trans was behind it.... Maybe someone else who has seen the vehicle might know....
Old Aug 2, 2012 | 08:10 PM
rocketraider's Avatar
Oldsdruid
I read somewhere that a BOP pattern transmission will bolt up by relocating one bolt ear. Which one IDK.
Old Aug 3, 2012 | 11:33 AM
The Aurora V8 is just a smaller displacement Northstar. The motors are externally identical. The 60 degree metric bolt pattern (used in S-10s and 3rd/4th gen F-body cars) needs only one bolt relocated and the top of the bellhousing modified to fit the starter. Cadillac Hot Rod Fabrications (www.chrfab.com) sells modified 700R4s and matching flywheels. Your biggest problem is the water pump, which is driven off the back of the driver's side valve cover, gets in the way of the brake booster in RWD applications. Note that Caddy did make a RWD N* for a few years in the SRX and STS applications. That trans will bolt up and those motors have a conventional front water pump.
Old Aug 5, 2012 | 03:28 PM
turbobill's Avatar
The metric bolt pattern (aka front drive pattern) was used on rear drive 700R4/4L60 transmissions on 60 degree V6 powered (2.8 and 3.1L) S10's/15's and Gen 3 Camaro/Firebirds. The electronic version (4L60E) with the FWD bellhousing pattern was used in the 60 degree (3.4L) and 3.8L Buick engined (90 degree) versions of the Gen 4 Camaro/Firebirds starting in 1994 model year.
These particular 700R4's used the smaller 27 spline input shafts used on all '82 to mid '84 700R4's. The torque converters on those transmissions are smaller in diameter because of the smaller bellhousing (12").
If you have a newer than mid 84 transmission, the guts can be put into the metric/FWD case. You'll need the front pump, input shaft/shell from the 82 to mid 84 or FWD version. The torque converter will have to come from the smaller bellhousing version, some other 12" 27 spline GM automatic, or aftermarket.
Olds92
Aurora
Dec 18, 2010 06:59 PM
CHRISD
Oct 12, 2006 05:19 AM
96 aurora
Aurora
Sep 6, 2006 03:49 AM
CHRISD
Aug 29, 2006 01:23 PM
HighHopingAurora
Aurora
May 15, 2006 02:33 PM
