leaky pan gasket
Old Oct 25, 2007 | 06:24 PM
dynamic88's Avatar
leaky pan gasket
okay. i am on about my forth time messing with the pan gasket since dropping the transmission in my 65 olds dynamic 88 w/ th400. it will not stop leaking around the front of the pan near the dust cover. i have replaced the gasket twice. the last time i dropped the pan i put ultra gray silicone sealer down, then the gasket and more silicone on top of that. it is still leaking. i put a level on the pan lid it shows level. im going to order another gasket and try again, but im about ready to weld it shut. does anyone have any ideas? can you buy new pan lids yet for these? chris
Old Oct 25, 2007 | 10:31 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
www.tciauto.com
Their pans are beautiful.... $200 beautiful though.
Old Oct 26, 2007 | 05:32 AM
dynamic88's Avatar
ouch!!!!!! okay thanks
Old Oct 26, 2007 | 05:53 AM
ozoneblue's Avatar
Try to get a cork gasket and glue it to pan with copper coat not the spray turn upside down put weight on it & let dry, Then coat other side & bolt on lightly in a pattern.do not smash the gasket Use carb cleaner to clean surfaces
Old Oct 26, 2007 | 11:06 PM
dynamic88's Avatar
ive been using the cork style. where do you get this copper coat? your not talking about the copper color silicone are you? do you know the torgue setting for the pan? i believe its 13 pounds, but not sure. chris
Old Oct 27, 2007 | 04:57 AM
ozoneblue's Avatar
NAPA & Orielys both have it here, Not sure on torque,13 inch pounds, ? I just snug the bolts down with a 1/4 " ratchet from right side to left in a pattern.Don't use silicone it has a tendency to squeeze out, your better off with no sealer. Copper coat comes in a brush on type can Shake well
Old Oct 27, 2007 | 08:39 AM
Even if the pan you have is flat it still may have dimples around each bolt hole. If the bolts were over torqued it could cause the gasket surface to have waves in it. This will lead to a bad seal. Be careful when using any kind of sealing compound on an auto transmission pan. An automatic transmission is not resistant to any kind of debris or gasket material in the fluid.
Old Oct 27, 2007 | 08:27 PM
dynamic88's Avatar
thanks guys. i will try a new cork gasket and see what happens.
Old Oct 29, 2007 | 03:57 AM
Jim's rare 80's Avatar
Jim's rare 80
Also make sure your bolt holes aren't recessed from past tightening. A trick I do with these issues is to put a 7/16 " socket on the bolt side of the pan, and tap the tranny side of the pan with a 1/4" short socket extension. This presses the bolt holes toward the bolt, and helps pull the pan tight between them. Just an idea.
Old Oct 29, 2007 | 06:22 AM
dynamic88's Avatar
okay thanks, chris
Old Oct 29, 2007 | 06:37 AM
Oldsmaniac's Avatar
Is the leak at the rear of the pan where the torque converter cover is?...Are you changing the rubber seals as well??...Are you sure the rear main oil seal is not leaking???
Old Oct 29, 2007 | 07:25 AM
dynamic88's Avatar
ive replaced the front and rear seals. the leak appears to be at the front of the pan gasket next to the torque converter cover. i dont think its the front seal. its been replaced, not that that means anything. ive taken the dust cover off thinking it was the front seal, but its been dry in there, so thats what leads me to believe its the front end of the pan gasket.
Old Nov 2, 2008 | 06:24 AM
trucker1's Avatar
probably leaking out of accumalator cover.
Old Nov 2, 2008 | 11:19 AM
dynamic88's Avatar
it actually turned out to be at the shift linkage. there is a oring that goes inside the side of the pan. so turned out to be an easy fix just lots of headaches until i figured it out. chris
kerchunkie
May 1, 2014 12:47 PM
MudEye
Jun 9, 2012 05:16 AM
dallasite21
Jun 20, 2010 05:37 AM
Olds64
Feb 17, 2009 01:20 PM
Gert3116
Sep 22, 2007 05:54 AM
