Need help with a leaky fuel pump
Old Sep 18, 2007 | 09:01 PM
Gert3116's Avatar
Red69CutlassS
My fuel pump went out a couple months ago and I replaced and it started leaking. I took it back off and replaced the gasket and cleaned it all up and it still leaks. If anyone has any tips I could use some.
Old Sep 18, 2007 | 09:52 PM
dynamic88's Avatar
maybe try some black silicone to see if that helps seal it up
Old Sep 19, 2007 | 05:15 AM
Oldsguy's Avatar
Past Administrator
leaking fuel or oil? I think you mean oil. Then the pump itself really isn't leaking the mating surfaces between it and the front of the block are. The block surface must be free of any old gasket debris or old silicone, etc. That area is hard to get to when the engine is installed with everything in the way, sort of a tight fit. I use a small mirror and flashlight to reflect light directly onto the surface and allow me to see how clean the surface is. Use a small scraper, small bits of emery cloth on the ends of my fingers etc to clean it off. If you have room (I doubt it) use a dremel tool with a buffing attachment, that is the one that is made of layers of white cotton pressed together. I did this but the fan and alternator and all the other stuff was off the engine. It turns fast enough to provide enough friction to clean the surface. Then clean with denatured alcohol or your favorite solvent. It really has to be clean. The same goes for the fuel pump mating surface but usually if it is new that isn't a problem. I pre-apply the gasket to the pump first with silicone and let it set up. That way it won't slip on me when I install it, a little silicone on the other surface and on it goes. If it still leaks, you may have a bad gouge or someone in the past has really worked on that surface and given it a depression so it isn't flat.
Old Sep 20, 2007 | 09:03 PM
Gert3116's Avatar
Red69CutlassS
My brother is a mechanic and he helped me install it and he said the block might be warped. have anyone ever heard of this.
Old Sep 21, 2007 | 03:24 AM
Oldsguy's Avatar
Past Administrator
No I haven't experienced that or heard of that but I guess it would be possible. That area of the block is pretty strong with not many large flat areas. I would think more that the surface has been made uneven by excessive "cleaning" with abrasives like sandpaper or a heavy scratch from a scraping tool, etc. But like your brother has mentioned, if it is warped that would cause difficulties getting a good seal.
Old Sep 21, 2007 | 06:10 AM
ozoneblue's Avatar
Are the Olds blocks like the SBC blocks? .With a 5/16 threaded hole above the fuel pump If so this bolt is known to leak, It is made for access to the fuel pump rod.use thread tape on this bolt when re installing. CAUTION if bolt is missing do not use one too long
Old Sep 21, 2007 | 08:24 AM
Oldsguy's Avatar
Past Administrator
They use a stud on the bottom and a threaded hole on top, not sure about the size. On the Oldsmobiles, the fuel pump has an integral armature that rides against the eccentric on the front of the camshaft, I don't think the hole is all the way through for access to a rod.
Old Sep 21, 2007 | 03:32 PM
I don't think the block would warp in that area.
Maybe if it was a Chevy engine. I hear that GM used Crest toothpaste in the late 60s to mid 70s as a material for Chevy engines. They would inject it into a mold and let it harden. You know, the way toothpaste gets hard on the sink when you forget to wash it off in the morning. That is why Chevy had to use four bolt mains. The metal wasn't really metal at all, just hardened toothpaste.
Old Sep 21, 2007 | 04:53 PM
ozoneblue's Avatar
Dont know what Olds used ,But my 54 dosent have many cavietys
Old Sep 21, 2007 | 10:33 PM
Gert3116's Avatar
Red69CutlassS
alright. i guess i'll take it off again and try a new gasket and clean it some more. thanks for the info.
Old Sep 22, 2007 | 02:29 AM
88 coupe's Avatar
Junior Member
Originally Posted by Gert3116
........ he said the block might be warped ........
Not a chance.
If the mating surfaces are clean and the gasket is new, the leak is elsewhere. Ask yourself: What changed when the leak started?
Clean the pump with brake cleaner so it is good and dry.
Get an athletes foot spray power (like Desonex), and spray any suspect areas with the spray powder. Take it for short ride. The power should change color showing you exactly where the leak is coming from.
Thanks, to oldsmobile1915, for this one.
Norm
Old Sep 22, 2007 | 05:06 AM
texasred's Avatar
Tom Servo's Stunt Double
Norm
I like that one!
C.J.
Old Sep 22, 2007 | 05:54 AM
That is a good idea, and it is alot cheaper than buying some of that Zyglo leak detector from the auto parts store.
kerchunkie
May 1, 2014 12:47 PM
Olds64
Feb 17, 2009 01:20 PM
dynamic88
Nov 2, 2008 11:19 AM
Oldsguy
Feb 29, 2008 07:11 AM
boese1978
Jan 22, 2008 11:56 AM
