Small block headers.
Old May 20, 2007 | 12:59 PM
67htc's Avatar
I am considering putting headers on my '67 Cutlass with 330 engine.
Does anyone besides Kooks make a decent set?
Thank you for any help offered.
Old May 22, 2007 | 07:25 PM
marcar1993's Avatar
If the heads are the same as a 350-403, hooker makes a set. I know they make good parts.
Old Jul 9, 2007 | 12:02 PM
texasred's Avatar
Tom Servo's Stunt Double
Love my DynoMax ceramic coated ones. Over 7 years old and still look fresh!
C.J.
Old Jul 10, 2007 | 04:50 PM
67htc's Avatar
Funny thing, T-Red.
I called Jegs' today. They sell Dynomax headers, but said there are none made by Dynomax for a '67 Cutlass with a small block.
But, thanks for your help...........
Old Jul 10, 2007 | 06:46 PM
Redog's Avatar
^^ Try Summit.
If you can buy headers for a 307, you can get them for a 330 no problem
Old Jul 10, 2007 | 06:54 PM
67htc's Avatar
Thank you for your input, Redog.
I believe the problem is not so much that the headers won't fit the engine; as it is they won't fit the chassis.
From everything I have learned so far, it seems that Kooks are the only headers that will fit without "hammer-tuning". Trouble is: Kooks are very pricey.
Old Jul 10, 2007 | 10:09 PM
Redog's Avatar
^ Yeah I ran into that problem with putting headers on the Delta with the 307. I figured since they'd fit the motor, it's wouldn't be a problem.
Cost me almost as much as the headers cost to ship them back to Summit
Old Jul 11, 2007 | 05:20 AM
Oldsguy's Avatar
Past Administrator
You should see the prices for Headers by Ed then....
Old Jul 13, 2007 | 09:36 AM
millwrightrice
Guest
Posts: n/a
You know headers sometimes aren't worth what you have to put in them compared to what you get back.My opinon.I have had really good performing engines with stock manifolds.There are tricks to them alsoorting,smoothing coating.Look for some dyno numbers and see if it is worth it before you spend a fortune.
Old Sep 23, 2007 | 06:49 AM
bonesbmx's Avatar
headers
ive just bought my dynaflow headers and have read the full instruction sheet. as far as i can see i should have no problems. will i have to lift the motor or lift each side as they slide in? i no they are made for the 350 motor but im wondering about any mods i might have to do. someone told me i should get new motor mounts since ill need to lift it anyway.
any experiences on a 71-72 would be great
thanks
Old Sep 24, 2007 | 09:52 AM
The problem is that the 64-67 frames are slightly narrower than the 68-72 frames. The 350 headers obviously bolt to the 330, but they may require a little "customizing" to clear the frame.
Old Sep 24, 2007 | 01:29 PM
Jokers69's Avatar
Senior Moment
thanks
my headers went into my 69 by removing the starter and the oil filter bracket and copious amounts of beer to lubricate...
Bernhard
Aug 24, 2014 09:59 AM
louie
Sep 15, 2013 10:39 AM
cycomiko
Sep 3, 2010 03:31 AM
citcapp
Jan 31, 2009 04:01 PM
z11375ss
Jul 12, 2008 08:49 PM
