55 Olds Hydramatic transmission - Newbie
Old Aug 31, 2006 | 06:28 PM
Pookster6's Avatar
Hi, I'm a newbie here, so any help would be most appreciated. I recently bought a 55 Olds Holiday with (I think) a 3-speed Hydramatic transmission. Car runs like a top, and the transmission shifts fine, but when I start the car and try to put it in gear (D,R, whatever, the indicator (I guess thats what you call it jumps around and I sometimes have to play with it to get it in D instead of S or Lo - it often pops into Lo at first). Once its in D and I'm moving, it shifts just fine. Any suggestions on what the problem is and what I can do? Thanks from a new "cool car" guy.
Old Sep 1, 2006 | 04:44 AM
Oldsguy's Avatar
Past Administrator
First, welcome to our site. Second, I have no experience with your tranny specifically but I would think that probably the detent mechanism that keeps the shifter indicator in position is the culprit. My experience with other atutomatic transmissions is that mechanism is actually in the transmission and not in the steering column. You might check all the linkage from the steering column, down the front of the firewall to the transmission, you may have some unusual loosness or play in one of the joint. Just an idea, hope you get it fixed.
Old Sep 1, 2006 | 08:03 AM
PetChemMan's Avatar
Your transmission is a 4 speed Hydra-matic. There is no shift indicator position for first gear. Second gear is "Low" , third gear is " Super", and "Drive" allows the transmission to shift into fourth gear. The transmission always starts in first gear, and then shifts to "Low" ( second gear). Thusly, you can't hold it in first gear, but you can hold it in second gear if the shift lever is in "Low". There is no full throttle kickdown into first gear, only into third or second. The shift indicator needle is usually controlled by a rather simple mechanism, sometimes just a string and a return spring in the steering column. You may not have to take anything apart.
As long as the transmission is shifting properly, your problem is minor, so get out your WD-40 and start looking for something to lubricate !
Old Sep 2, 2006 | 06:21 PM
PetChemMan's Avatar
I honestly don't recall how the gear indicator is operated in a '55, although it probably is the same as a '54.
Old Jan 13, 2016 | 07:38 PM
Frank Allen's Avatar
55 shift indicator
The shift indicator is electric, and is the same on 54.
Frank Allen
Old Jan 13, 2016 | 11:02 PM
Ozzie's Avatar
As mentioned, the indicator is electric, is adjustable, and is covered on pages 3-97 and 3-98 of the 1955 Oldsmobile Shop Manual.
Old Jan 14, 2016 | 02:29 AM
ignachuck's Avatar
Frank Ignachuck
Frank Allen
See that? You just have to be patient on this site. Sometimes it takes us over nine years, but we always come up with the answer
roberer
Apr 3, 2016 01:58 PM
scharpp
Mar 17, 2015 06:20 AM
scharpp
Mar 4, 2015 10:26 AM
scharpp
Jan 26, 2015 01:50 PM
Jet Doc
Nov 2, 2008 11:55 AM
