transmission shift
transmission shift
I am having trouble with my car shifting.It shifts to late.I have a cable thats below the accelarator cable that comes from the firewall and and goes into the transmission.Is this the detent cable and if so how do i adjust it?I have a 350 tranny by the way and my car is a 1972 cutlass supreme.
Thank you joe for your input.I will definitely look into it.
Actually, the inner governor weights dictate upshift at wide open throttle, teamed up with the vacuum modulator. You can get a kit BY B&M and adjust the shift points. Works great. Works for the 350, 400, and 700r4 trannys. Was the 350 trans a transplant? If you have wires on the a switch mounted to the gas pedal bracket, that's for a 400 (electric detent).
Picking up an old thread. I was under the hood of my 350 olds rocket Sunday and noticed what appears to be the vacuum tube which goes into the valve cover was not connected. I connected the two. Took the car out tonight and is suddenly shifting very, very late. Immediately disconnected the hose, but still shifts late. Any thoughts? Was shifting perfectly before this...
Amazingly, it was the small rubber hose that connects from the small metal line from the transmission, near the carburetor end (see picture, does that seem right?).
http://i1065.photobucket.com/albums/...psnpllugzs.jpg
I say amazingly, because – full disclosure – I don't know this engine that well (I've had the car a total of 27 days). I was pretty surprised to find that such an innocent-looking, small rubber hose could be the culprit of such monstrous proportions (*relatively speaking).
I am further surpassed that it is not clamped on, along with the other two hoses that connect to this triple-tree. Should it be?
Same here, now I just open I didn't create any damage to the tranny or engine by driving it with that issue for so long (about 45 minutes).
the tranny was screaming as it winded out first gear to 50+ mph!
If you have the OEM steel line check it for restriction. Also pull the governor and make sure there isnt any burrs on the shaft or the bore and it spins freely and everything's intact. Use fine emery if any burrs are found.
hvysupreme
Feb 18, 2017 12:40 PM
Alocatelli
Dec 10, 2012 07:49 AM
