transmission shift
Old Jan 7, 2008 | 03:01 PM
projectheaven's Avatar
transmission shift
I am having trouble with my car shifting.It shifts to late.I have a cable thats below the accelarator cable that comes from the firewall and and goes into the transmission.Is this the detent cable and if so how do i adjust it?I have a 350 tranny by the way and my car is a 1972 cutlass supreme.
Thank you joe for your input.I will definitely look into it.
Old Jan 9, 2008 | 05:18 AM
Oldsguy's Avatar
Past Administrator
I think that cable is the kickdown function for full throttle 3 to 2 downshifts, not upshifts.
Old Jan 9, 2008 | 11:53 AM
Which cable controls upshift?
Old Jan 9, 2008 | 12:26 PM
W30post's Avatar
The modulator valve and vacuum control the upshifts. A pinch in the vacuum line or a bad modulator could be causing this late shift.
Old Jan 9, 2008 | 03:53 PM
An improperly adjusted kickdown cable would make the trans think the throttle was floored and would inhibit upshift.
Old Jan 9, 2008 | 09:24 PM
There are 2 wires going into the top of my accelerator pedal.I know one is the kick down.What is the other one? I have a 72 cutlass supreme with a 350 rocket and 350 tranny.
Old Jan 10, 2008 | 09:28 AM
Do you mean "wires" as in electrical or cables as in throttle and kickdown?
Old Mar 6, 2008 | 10:34 AM
Goose's Avatar
Actually, the inner governor weights dictate upshift at wide open throttle, teamed up with the vacuum modulator. You can get a kit BY B&M and adjust the shift points. Works great. Works for the 350, 400, and 700r4 trannys. Was the 350 trans a transplant? If you have wires on the a switch mounted to the gas pedal bracket, that's for a 400 (electric detent).
Old Mar 6, 2008 | 08:36 PM
88 coupe's Avatar
Junior Member
We have another knowledgeable addition to the site.
Welcome Goose.
Norm
Old May 20, 2015 | 08:08 PM
Sunshn's Avatar
Picking up an old thread. I was under the hood of my 350 olds rocket Sunday and noticed what appears to be the vacuum tube which goes into the valve cover was not connected. I connected the two. Took the car out tonight and is suddenly shifting very, very late. Immediately disconnected the hose, but still shifts late. Any thoughts? Was shifting perfectly before this...
Old May 20, 2015 | 08:29 PM
Are you talking about the PCV valve? Did you disturb the modulator line?
Old May 21, 2015 | 04:19 AM
Sunshn's Avatar
I might have. Trying to identify that now. Not certain what to look for .... under air cleaner I assume
Old May 21, 2015 | 04:57 AM
Theres a rubber hose that connects to a small metal line that runs to the transmission connected through another rubber hose to the modulator.
Old May 21, 2015 | 08:09 AM
Sunshn's Avatar
Amazingly, it was the small rubber hose that connects from the small metal line from the transmission, near the carburetor end (see picture, does that seem right?).
http://i1065.photobucket.com/albums/...psnpllugzs.jpg
I say amazingly, because – full disclosure – I don't know this engine that well (I've had the car a total of 27 days). I was pretty surprised to find that such an innocent-looking, small rubber hose could be the culprit of such monstrous proportions (*relatively speaking).
I am further surpassed that it is not clamped on, along with the other two hoses that connect to this triple-tree. Should it be?
Old May 21, 2015 | 08:13 AM
No, generally vacuum hoses are not clamped. Glad it was something simple.
Old May 21, 2015 | 08:26 AM
Sunshn's Avatar
Same here, now I just open I didn't create any damage to the tranny or engine by driving it with that issue for so long (about 45 minutes).
the tranny was screaming as it winded out first gear to 50+ mph!
Old May 21, 2015 | 08:38 AM
Probably not
Old May 21, 2015 | 09:22 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
If you have the OEM steel line check it for restriction. Also pull the governor and make sure there isnt any burrs on the shaft or the bore and it spins freely and everything's intact. Use fine emery if any burrs are found.
hvysupreme
Feb 18, 2017 12:40 PM
Alocatelli
Dec 10, 2012 07:49 AM
Oldsproject
Apr 23, 2010 04:19 PM
ctrain22
Sep 7, 2009 10:54 AM
lowdynamo
Jan 9, 2009 09:49 AM
