lock up converter
Old Mar 19, 2008 | 04:59 PM
don71's Avatar
same but different
lock up converter
I MIGHT be using a later model 350C with lock up converter, 1980 or 81. It was cheap---and would be temporary. Besides, its "rebuilt"
Any worrys or damage that might occur IF I don't use the lock up function? Well......besides lower fuel economy?
I'm not spending 175 bucks on a lock up kit if I don't have to. Call me cheap, just use a capital C.
Old Mar 19, 2008 | 05:13 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I have a freebie stock converter here, if you want it. 74000ish miles.
Is the difference in the converter or the trans itself?
Old Mar 19, 2008 | 06:31 PM
don71's Avatar
same but different
Its both, mostly in the converter and some changes in the trans to my understanding. A lock up converter can only be used in lock up trans, from what I've gathered, you can't mix and match.
Old Mar 19, 2008 | 07:00 PM
I didn't know there even was a 350C lockup until a month or 2 ago. Go figure. Oddities
How are you going to run the wiring harness?
Old Mar 19, 2008 | 09:24 PM
It depends on how long you plan to run this "temporary" trans (I've driven "temporary" cars and parts for years - until a new failure made me do it right. ) Of course, is a $2.00 toggle switch cheap enough for you?
Old Mar 21, 2008 | 04:49 AM
don71's Avatar
same but different
I must admit I forgot about the toggle switch for manual operation. Just got to remember to use it! (turn it off). The speedometer will be another problem too. Thanks for the comments.
Old Mar 25, 2008 | 02:05 PM
Ndn_GivR's Avatar
I got a kit from Superior Transmission Parts Inc, Mine was for the 200c, its just a shift correction kit that corrects lock up problems, hav`nt installed it yet though. Still snowing here. They have kits for the C trannys. It was 35.00 bucks off of E-Bay.
Old Jun 3, 2008 | 07:45 PM
chivo80026's Avatar
I got a th350 from a 1979 Cutlass would i be able to install it on my 84 cutlass even tough it dosen't have a lockup solenoid like my stock th250 transmission?
Old Jun 4, 2008 | 07:41 AM
Yup, it bolts in. Just tie the old connector up someplace so it doesn't get damaged and short out.
Old Jun 4, 2008 | 03:14 PM
chivo80026's Avatar
oh ok thanks,
Old Jun 4, 2008 | 05:29 PM
I assume your 84 has either a V6 or the Olds 307, right? If it's a Canadian car with the 305 Chevy, then the bellhousing bolt pattern is different.
Also, if your 84 still has the computer controlled carb, you'll need to be sure the speedo gears are close to being right for your rear axle ratio. If not, the computer will read the wrong road speed, which may affect the mixture ratio in the carb.
Old Jun 30, 2008 | 11:11 AM
chivo80026's Avatar
i bolted everything up cooling lines, torque converter and everything. the engine started up fine. but when i go to drive the car just seen like it stay in neutral no change whether its park drive reverse. i noticed when i bolted the torque converter it moved forward a lil is that normal? or i wonder if there is a difference in the size of the converter?
Maverick
Apr 22, 2014 05:04 AM
van Dyck
Jun 23, 2013 08:39 PM
randomarrival
Dec 22, 2012 12:28 PM
easytobedead
Nov 29, 2012 11:59 AM
84oldsDelta88
Apr 2, 2010 08:20 PM
