3-speed conversion: column to floor
Old Nov 12, 2007 | 06:40 PM
jimrockford's Avatar
Hey all: My car is a bit of an odd duck, so I'm not sure if this is plausible. I have a 3-speed MANUAL transmission, column mounted ("3 on the tree"). I want to move the shifter to the floor. I've looked through the Hurst website, and can't find any information on which shifter will work with my car, because...
-I have a 231 V6
-I have a bench seat
-The car is a '77 Cutlass
-I only want to change the shifter, not the whole transmission
-I don't know which transmission I have (how do I find out?)
It seems like this should be a pretty simple job once I get the hole punched in the floor, but what then?
Old Nov 12, 2007 | 06:47 PM
-I have a 231 V6
Your car should have a Saginaw three speed. Hurst makes shifters for that trans. You may need to buy one of their optional sticks to clear the bench. Your car may be one of the last "three on the tree" cars build by GM, however.
shamusj
Apr 27, 2021 05:45 AM
Bitburger
Dec 30, 2012 04:49 PM
Gixxere
Aug 23, 2011 10:27 AM
rlang
Nov 7, 2009 01:52 PM
steve-landy
Sep 6, 2007 02:07 PM
