slim jim replacement
Old Aug 25, 2007 | 04:20 PM
GeneS12320's Avatar
airbagged 63 98
I have a 63 98 with a 394 and slim jim trans. I have always been unhappy with the trans. I am going to do the trans adapter and a TH350 or a 700R4. I am leaning towards the 700R4. Has anyone done this swap? Does anyone have any comments of suggestions?
Old Sep 14, 2007 | 09:03 PM
Natas's Avatar
Gene,
I just did a swap in my 62. But I went with a 200-4R because it was a smaller compact design. But the stock 200-R4 probly can't handle the weight of the car. Mine is GearStar built (beyond stock for over 300+hp) with a Bendtsen's Trans Adapter. It all bolted together smooth. I then had to cut my transmission tunnel out to get it in the car. I did a standard cross member on the transmission and for my motormount I uses the stock crossmember (Shimmed down) and made new mounts with standard GM trans mounts and some well crafted angle iron. Those were attached to two bolts that went through the adapter and into the block. I haven't got a drive shaft in it yet. But I can't to see how many MPG I through down.
Old Sep 15, 2007 | 06:46 AM
Here is an older thread on a similar subject. I have a 64 98 with a Slim Jim and it is a piece of junk. I am considering replacing the engine and transmission. Natas, about how much did it run you to replace the tranny?
https://classicoldsmobile.com/forums...94-1962-a.html
Old Sep 28, 2007 | 02:31 PM
Natas's Avatar
Alot, but it is a performance transmission. Junk yard trans can be had for cheap.
GeneS12320
Apr 28, 2008 06:39 AM
exmoparluver
Mar 31, 2008 03:08 PM
RatRod
Mar 22, 2007 08:17 PM
bjtstarfire
Drivetrain/Differentials
Dec 6, 2006 09:56 AM
