Tranny fluid for 83 Hurst THM200-4R
Old Oct 3, 2014 | 03:21 AM
83Hurst#1812's Avatar
Just purchased a 83 Hurst/olds...THM200-4R tranny ...Car has sat for for many years before i got it....It does run good and drives.
Book calls for Dextron II....Not avail anymore ...Many diff tranny fluids out there now..
Want to drop the pan ,,change gasket and filter and refill a few times...What tranny fluid are you guys using these days ??
Old Oct 3, 2014 | 03:49 AM
bccan's Avatar
Dex III, that's basically what it was designed to run on. Some folks like to flush them through & run Dex VI which is a "better" fluid but designed for different friction technology.
Old Oct 4, 2014 | 12:13 PM
TexasT's Avatar
Lots of miles? Fluid nice n red?
Careful swapping fluid on a real high mile car. It never seems to work out for me.
Old Oct 13, 2014 | 08:02 PM
442Classic's Avatar
Dex VI in both of mine.
Old Oct 14, 2014 | 01:05 AM
johnnyjaws's Avatar
use atf its like thicker almost like putting b&m trick shift fluid in it I learned this when I went to automotive school in the 70s its what I use gives u harder shifts
Old Oct 14, 2014 | 04:30 AM
pavemobile's Avatar
pavemobile
Redline D4 is what I use in the same tranny. I have an additional cooler plumbed in series after the internal radiator cooler. Add a couple of additional magnets to the pan while you're in there.
Mak
May 31, 2013 01:56 PM
navvet
Mar 6, 2012 07:57 PM
ddx77
Drivetrain/Differentials
Jun 7, 2010 01:01 PM
cfair
Brakes/Hydraulic Systems
Jun 8, 2009 12:37 AM
scrappie
Apr 9, 2008 05:17 PM
