corvette zf 6 speed in 68 442
Old December 27th, 2014, 04:06 PM
jordan845's Avatar
Cool corvette zf 6 speed in 68 442
Hi all I got corvette zf 6 speed manual transmission. Has anyone put a zf 6 speed in 68 442 ?
jordan845 is offline
Old December 28th, 2014, 08:49 AM
Mr Nick's Avatar
How does the size compare to a T56? If the ZF is the same or larger, will you must likely have to cut the floor board.
Does it use the same bolt patten as a T56? That will determine your bellhousing options.
What type of clutch are you going to use?
I have a RS500 in mine, so I can't answer specifics on the ZF, but may be able to offer general advice/experience on other aspects.
Also, just curious why you didn't go with a T56?
Mr Nick is offline
Old December 28th, 2014, 02:44 PM
jordan845's Avatar
I got the transmission , bell housing , drive shat , shafter , throw out bearing , presser plate , cluch , paddles all for 800 . That's why I got and it should be here this week ?
Old December 28th, 2014, 03:11 PM
2blu442's Avatar
I ran a 1991 ZF 6 speed in a 1970 442 for several years. You'll have to cut the transmission tunnel for the shifter being further back. The gearbox itself fit under the tunnel, tight but it fit. The overdrive solenoid on the drives side will need to be removed or the floorboard notched. You'll need an adapter plate for the bellhousing to engine. If using the ZF bellhousing you'll need to use the hydraulic clutch, I didn't do this but it would have likely been a cleaner setup. I had an Olds bellhousing modified for the ZF transmission bolt pattern. You'll need to fabricate a mount for the transmission tail and get the correct driveshaft angle. The aluminum driveline from the Corvette is too short, so you'll need to have one made with the correct slip yoke for the transmission tailshaft. I had it behind a 455 with a mild build and used the car as a daily driver back in the 1990's. I'm not sure the transmission would hold up to the torque at the drag strip. But the 0.75 fifth gear and 0.50 sixth made the 4.10 rear end much more of a highway cruiser. This is more work but cheaper than one of the newer 5 or 6 speed manual transmissions. I did cut up the floorboard more than I wanted to and might think twice about doing it to a 442 again, but wouldn't hesitate for a Cutlass or Vista Cruiser. Please take lots of photos to share so others who consider this swap can learn from your work. John
2blu442 is online now
Old December 28th, 2014, 03:27 PM
jordan845's Avatar
Thanks , how did you do the cross member?
Old December 28th, 2014, 06:52 PM
2blu442's Avatar
I don't remember if I had to move the crossmember or not. But you'll need to fabricate the mount. The Olds used two bolts side by side. The ZF transmission uses two bolts stacked front and back.
John
Old December 29th, 2014, 07:00 AM
Well, the bellhousing will have a Chevy pattern, so that won't bolt to an Olds motor. The ZF trans uses a unique bolt pattern to the bellhousing that won't fit normal BOP bellhousings. I'm not aware of anyone who makes an aftermarket bellhousing for this application, though many make bellhousings to adapt the ZF to an LS motor. Try QuickTime for a custom bell, just expect to pay more than you did for the trans. The aftermarket Chevy-to-BOP adapter plates don't work with a manual trans, they are for automatics. The bottom two bolts and the dowel pins on the Chevy bellhousing are common to BOP if you want to cut and weld the Chevy bell.
The driveshaft and pedals are useless, as they are Corvette parts that won't fit the Olds. And of course, unless your engine came from the factory with a manual trans, the crank won't be drilled for the pilot bearing.
joe_padavano is offline
Old January 10th, 2015, 05:28 PM
jordan845's Avatar
I got my transmission in today. here are some pixs.
Old February 27th, 2015, 07:37 PM
jordan845's Avatar
I had to cut drive shift 4" it was $20 . I got it in.
Old February 28th, 2015, 06:16 AM
allyolds68's Avatar
I'm curious why modifying a BOP bell housing wouldn't be the simple solution. It seems any decent machine shop could locate the holes or even fabricate an adapter plate if the bolt pattern of the ZF trans was outside the limits of the BOP bellhousing.
John,
Why wouldn't the mechanical clutch work if you used a BOP bellhousing?
allyolds68 is offline
Old February 28th, 2015, 07:18 AM
jordan845's Avatar
It was a lot easier to use the chevy bell housing. I got adapter plate so it would bolt up and trim the bottom and two fins trimmed so the flywheel would clear. Plus with so this setup you don't have to adjust the clutch .
Old February 28th, 2015, 09:41 AM
allyolds68's Avatar
What adapter plate did you use? What clutch set up are you using?
Old February 28th, 2015, 10:23 AM
RandyS's Avatar
Your pics don't show up for me..........
RandyS is offline
Old March 2nd, 2015, 04:11 PM
jordan845's Avatar
Old March 2nd, 2015, 04:17 PM
jordan845's Avatar
Old March 2nd, 2015, 05:02 PM
RandyS's Avatar
I still don't see any pics. Anyone else able to see them?
RandyS is offline
Old March 2nd, 2015, 05:12 PM
jordan845's Avatar
68 442 with zf 6 speed
How are the first photos
Old March 2nd, 2015, 05:14 PM
67442nut's Avatar
Nothing for me either.
67442nut is offline
Old March 2nd, 2015, 05:15 PM
67442nut's Avatar
There ya go.
67442nut is offline
Old March 2nd, 2015, 06:00 PM
jordan845's Avatar
I have more tomorow
Old March 26th, 2015, 04:38 PM
jordan845's Avatar
Here is some update pics
Old March 26th, 2015, 04:41 PM
jordan845's Avatar
2 more
Old March 27th, 2015, 05:52 PM
Mr Nick's Avatar
No turning back now!
Is the gas pedal as close to the bellhousing and slave cylinder as it appears?
Mr Nick is offline
Old March 27th, 2015, 07:51 PM
jordan845's Avatar
Yea but it will be ok
Old March 28th, 2015, 11:47 AM
NOVICE car nut
oldsguybry's Avatar
I've been told that a lot .
oldsguybry is online now
HonestDave
June 18th, 2015 04:28 AM
basssnake
January 16th, 2011 12:26 PM
Man In Black
Cars Wanted
October 23rd, 2010 02:09 PM
olds4life
August 13th, 2010 08:16 AM
nonhog
November 26th, 2009 12:22 AM
Quick Reply: corvette zf 6 speed in 68 442
