67 442 Auto Speedometer Drive Gear
Old Apr 17, 2014 | 07:10 AM
SHJohnson's Avatar
What speedometer drive gear is in a 67 442 TH400 with a stock 3.08
differential and 14" tires? I'm having a 3.55 posi installed. I need to know so I can obtain the correct driven gear to have it on hand when the work is done. Can't find the stock drive gear info anywhere.
Old Apr 17, 2014 | 08:55 AM
Originally Posted by SHJohnson
and 14" tires
Can't answer this question without knowing the size of the tires. 14" is the size of the RIM. Unless you are running with the tires flat, we need to know the outside diameter of the TIRE.
Old Apr 17, 2014 | 11:15 AM
SHJohnson's Avatar
Joe, Thanks for the reply. The tire diameter is 25.9", a 205/70-14. That was the factory stock tire, so I'm looking for what the speedometer drive gear is as it came out of the factory. One website defaulted to a 15 tooth gear in their calculation algorithm in the th400 section of their site. I can't confirm the 15. Another web site said it was probably a 17 0t 18.
65Delta
Jul 15, 2023 08:15 PM
David Man-Man Manley
May 11, 2013 06:02 AM
Hairy Olds
Dec 26, 2012 11:30 AM
jensenracing77
May 3, 2011 05:27 PM
one4theroad
Mar 18, 2010 11:31 PM
