Th350 swap to 4-speed?
So, I have a 1969 F85 with a th350 which is hooked to a 350 engine, and was wondering if it is plausible/ how much it would cost to put a 4 speed manual in it.
Im switching over a turbo 350 tranny over to a 4spd in a 70 cutlass. Costing me about $4000. That's with a new 4 speed M22 rockcrusher Autogear, Centerforce clutch and pressure plate, drilling crankshaft for pilot bearing and other parts to convert over. Not including the price of a SFI explosion proof bellhousing.
I'd suggest you start by using the SEARCH function, as this has been covered about a bazillion times here. Bottom line is the major problem is that the crank in your engine won't have been drilled for the manual trans pilot bushing.
Big Mikey
Mar 27, 2013 06:51 AM
