Backyard shed mods for a TH400
Old May 5, 2014 | 09:00 PM
73aussie455's Avatar
Acceleratii maxim rapidus
Hi all.
Well it looks like the motor will need to come out for the mods I want to do, and then I MAW detail the engine bay somewhat as I've been spurned on into action by some of the great threads I've been reading.
So I MAW also take out the TH400 and clean it up too after an inspection.
Question is, has anyone done the mods that firm up the 1-2 and 2-3 shifts I've been watching on youtube, ie drilling out the 2 & 3 feed holes, leaving the spring out of the 2-3 accumulator piston?
Has anyone had success with these seemingly basic free modifications?
Old May 5, 2014 | 10:07 PM
brddg's Avatar
MAW buy a shift kit.
Old May 5, 2014 | 10:23 PM
I agree, buy a quality shift kit like a Trans Go.
Old May 6, 2014 | 02:21 AM
nsnarsk65cutlass's Avatar
Modifying a used trans is not a good idea,now if it's being rebuilt that's ok.Nick
Old May 6, 2014 | 08:32 AM
455man's Avatar
I've done those mods on a tranny that was given to me about 15yrs ago. My TH350 went out so i took the pan off, drilled the holes a little bigger, pulled the spring, took out a few checkballs and put it in the car. It shifts good. Got about 10k miles on it after the mods. No idea how many miles are actually on the tranny but I dont think it's ever been rebuilt.
Old May 6, 2014 | 09:29 AM
Octania's Avatar
"took out a few checkballs"
Seriously?
8-0
Just removed a few parts at random, or was there a clever plan to this?
Old May 6, 2014 | 11:49 AM
455man's Avatar
Seriously. Some tranny's come with 6 checkballs and some are not needed.
http://www.jegs.com/InstallationInst.../130-20260.pdf
Step 9 and figure 11 explains which ones to keep. I figured the OP knew about the checkballs since he has researched it.
Old May 6, 2014 | 05:12 PM
Thanks 455man. I have researched the mods extensively and am considering some of them for my TH400. I really wanted to hear from someone with REAL experience doing these mods, not just the virtual cyber ones so thanks for that.
Octania, these transmissions have been around for long enough now that some very clever trans mechanics have, through trial, error and time, worked out how to get the best from them and how to mod them without doing damage, to suit their particular applications.
There is a wealth of info out there on modding the TH400 and 350 transmissions to various levels of performance. There is a standard set of easy basic mods that have been tried and tested over time, so I would feel confident I'm not screwing up my trans. Yes, a shift kit does give the same mods but i'm a tinkerer kind of guy.
Changing shift points by changing the weights also doesn't seem so hard when you research the process, but just a little more complicated.
Old May 6, 2014 | 06:36 PM
If your comfortable removing the pump and valve body this is basically what I do for my street performance transmihttp://jakesperformance.com/TH400_Rebuild_Tech.htmlssion builds
Get a service manual that covers TH400 overhaul procedures. Trans-Go is the only shift kit that can dual feed 3rd gear without transmission dissasembly. In my opinion, if the transmission is out of the car, following Jakes tips is a much better and cheaper way of doing it. The shift kit does the same basic thing by blocking the hole in the case where you would have to install the freeze plug, and blocking the hole in the valve body where you would install the set screw.
If your using a stock converter or slightly above stock follow trans-go or Jakes drill sizes. If the stall speed is in the 2800-3000 or higher range drill both holes to 3/16th. If you can locate an extra horseshoe shaped shim for the pressure regulator valve use 2 and the stock blue spring, this will provide about 180psi of line pressure.
If the transmission is in good shape installing a shift kit wont hurt anything. If the trans needs rebuilt or is nearing the end of its life following these instructions, with good performance friction clutch plates a TH400 will easily handle 600-700 hp.
5998DownUnder
Feb 19, 2013 11:00 PM
TRW
Jan 21, 2011 05:38 AM
ls442
Nov 11, 2010 10:45 PM
olds69er
Apr 14, 2008 06:45 PM
<George>
Drivetrain/Differentials
Jul 12, 2004 11:00 AM
