1969 442 4-speed M20
I have my trany apart and need a new input gear. It is a 21 tooth, 10 spline input...so I assume I have the Muncie M20??
Is there any advantage to the M21 close ratio over the M20 wide ratio? I'm not racing the car...just street application. I have the Type "0" differential but don't know what gears are in it. [can't seem to find the codes that are supposed to be stamped into the axle tube on the inboard, passenger side].
I can find the ratio by turning the drive shaft and counting the wheel revs...but what would you recommend for a good trany/differential combo?
Not sure about the method you used to measure your ratio. But if you've never changed the oil in the rear end this might be a good time. Then you can pop the cover and read off the ring gear the number of teeth in each the ring and pinion, divide to get the ratio.
I had a 1968 4 speed Cutlass many years ago. It had an M21 with a 3.08 rear end ratio. In town it would leap off the line and half way across the intersection... I couldn't slip the clutch enough to make it comfortable to drive. I swapped in a 3.31 and it was much more fun. So I'd be surprised if your car had a 2.78. Not trying to be critical of your method but my experience is that you should have a 3.23 or lower ratio behind a factory 4 speed car.
John
John
My son turned the wheel ten revolutions and I counted the number of revs on the drive shaft. Thought I counted 28 revs but I'll try it again to see what I get. Good suggestion on changing the oil... Will do
3g87xm
Jan 4, 2014 08:37 AM
