installed a 200R4 in my 64 F-85 post car
Guys I have a modified 200R4 in my 64 F-85 pro-touring build and really wish to keep the 2-speed column shift for that granny look. I bought a Kugul Komponents transmission shift arm kit. Can I make this work?
Rob, I believe the shift linkage sets park thru neutral and the trans sets the gear selector positions. I run a T400 with my column shift, and it goes thru all the gears but on the selector it only shows the original 2 speed. What I think may happen is possibly you may lose the manual 1st gear selection unless your kit corrects that.
Thanks I got it in but it's bidding a bit, probably needs some tweaking or I have to double check and make sure I put the column back together the right way! I will get some help this weekend, that kinda stuff is hard to do by yourself.
