1968 cutlass Tilt installed into non tilt car
Old Mar 20, 2011 | 02:07 PM
1968Cutlassfallbrook's Avatar
Hello,
I think I know the answer but wanted to double check is a non tilt and tilt wheel wire harness the same? Just a simple plug and play or is there other modifications needed?
Old Mar 20, 2011 | 02:41 PM
Far as I know all GM will interchange within body stye and year range.
Just put one in my '73 2 days ago. Easy as 1-2-3.
Old Mar 20, 2011 | 02:50 PM
starfire's Avatar
Yes, it should plug n play. The bigger question would be where in the hell did you find a '68 tilt column? They're not easy to find and not cheap if you do find one!
Old Mar 20, 2011 | 09:27 PM
I was just curious if they were the same or not as my buddy had bought a tilt and it looks the same as a cutlass and was wondering if they were a plug and play. are the factory tilts better then the aftermarket tilts or are they the same?
Old Mar 20, 2011 | 09:34 PM
They make aftermarket tilts?
Old Mar 20, 2011 | 09:37 PM
yeah they show them on ebay
Old Mar 21, 2011 | 05:16 AM
gearheads78's Avatar
car guy
I believe 68 is a one year only column so you need to make sure thats what he has.
Old Mar 21, 2011 | 07:30 AM
Let's start again. A FACTORY 1968 tilt column is a bolt-in, plug-in. All bets are off on aftermarket columns. Most of these are based on the later model columns and wiring and may or may not match up to a 68 without some mods.
Old Apr 7, 2011 | 05:06 PM
So what's a factory tilt worth if I'm able to locate one? what's the most you have seen them go for?
starfire
Dec 9, 2021 08:21 PM
Vistabrat72
Apr 2, 2012 06:38 PM
ELECMAN
Jan 22, 2012 01:49 PM
72oldscutlass442
Feb 24, 2010 02:10 PM
