2004r manual shifting question
Old Feb 13, 2013 | 03:18 PM
72CUTTY's Avatar
Hi guys, its been a while since I've been here. I have a quick question. I installed a 2004r on my 72 cutlass and kept the original PRNDSL cluster. I try to manually shift the tranny, and i only seem to have just PRNDSL. i thought with the 200r4 i would get a "extra gear" Is there a problem with my tranny?. When i just leave at at "D" and cruise around i do feel the 4th gear kick in. Thanks
Old Feb 13, 2013 | 04:41 PM
You actually have PRN432. Your shift quadrant is not allowing you to manually shift into first. As you note, the trans will use all four gears if left in D (actually now OD, the new D is in the old S position, etc.). If you have a floor shifter, Shiftworks sells a conversion kit that lets your stock shifter manually access all four forward gears.
Old Feb 14, 2013 | 07:59 AM
72CUTTY's Avatar
Thanks for that Joe! It makes sense. I have been reading post on various web pages and i was afraid my tranny was going to give up soon!
442Dave
Mar 4, 2012 02:59 PM
jonstringer
Jun 3, 2010 09:36 PM
TedH
Jan 23, 2009 07:42 AM
Edveen
Feb 28, 2007 11:12 AM
kjones6039
Jul 7, 2006 06:44 AM
