Help with removing th350 from 70 cutlass
Old Apr 16, 2013 | 06:44 PM
Finn5033's Avatar
Hello I was wondering if anyone knew of a thread that walks through the removal of a th350 with floor shifter. I have the engine out and the tranny is being held up by a floor jack. I have the entire car up on jack stands as well. I have never done this and want to do it right so I don't break anything. Any help would be great, thank you.
Old Apr 16, 2013 | 06:49 PM
Remove driveshaft.
Disconnect shifter.
Disconnect speedo drive.
Disconnect TCS wire, if connected.
Remove crossmember-to-transmission bolt.
Remove two nuts and bots holding crossmember to frame on each side.
Jack transmission up a bit.
Remove crossmember.
Lower transmission (if tailshaft tips down, it with spew oil).
Old Apr 16, 2013 | 07:07 PM
Finn5033's Avatar
Is it better to drain the tranny oil before or after removal?
Old Apr 16, 2013 | 07:12 PM
Originally Posted by Mechanic
Remove driveshaft.
Disconnect shifter.
Remove crossmember.
Don't forget the cooler lines and kickdown cable!
Pretty much a textbook how to procedure. If you can get the pan off to drain it that would be good. Maybe you will be lucky and have a trans pan with a factory drain plug.
Old Apr 16, 2013 | 07:27 PM
Finn5033's Avatar
There is no drain plug but that answers my question about draining before or after removal. Thank you
Old Apr 17, 2013 | 03:45 AM
No matter what you do, you will get fluid out the tailshaft, so be prepared.
And, yeah, lines and kickdown.
And vacuum line to modulator.
Old Apr 17, 2013 | 07:40 AM
Draining it before will at least reduce the size of the oil spill when you do pull the trans.
blowitup
Jun 10, 2014 12:05 PM
billmerbach
May 16, 2014 11:39 AM
71cutlass350
Mar 18, 2013 11:42 AM
Aceshigh
Nov 1, 2010 03:54 PM
veltboy618
Mar 26, 2009 08:27 PM
