Correct 4spd for 1972
Old Jul 31, 2013 | 11:59 AM
1320dragmonza's Avatar
What Muncie was factory in 1972 Cutlass, particulaliry a W30? I believe the M22 was 71 only. Was it close or wide ratio? M21 or M20? What size was the drive shaft yoke and also clutch size?
Thanks,
Bill
Old Jul 31, 2013 | 12:29 PM
wmachine's Avatar
Trying to remember member
The SPECS booklets will give you the trans and clutch availability. Free of charge at Wild About Cars:
http://wildaboutcarsonline.com/cgi-b...aldisplayed=50
All are Muncies that you are asking about. M21 and M22 were close and the M20 is wide. Clutches are all 11".
Wild About Cars. http://wildaboutcars.com. An information supersource, especially Oldsmobile. More Olds content than anywhere else on the internet and continuing to grow.
You'll find Chassis Service Manuals, Product Information Manuals (AKA Assembly Manuals), Inspector's Manuals, and other documents that will contain this and much much more.
Dealer Brochures, magazine ads and articles, and the Automotive History Preservation Society library growing daily.
Free to join, free to learn.
Old Jul 31, 2013 | 12:46 PM
507OLDS's Avatar
The 1972 Cutlass/442 came with the M20. Fine-spline input,large output.661 main case,764 tailhousing,648 side cover
Old Aug 1, 2013 | 03:13 AM
Yellowstatue's Avatar
Was also available with W37, dual disc clutch!!!
Old Aug 1, 2013 | 08:52 PM
Thanks guys,
Brian was the specs you gave true for the W30 also or was it was the same either way.
Was the W37 more a performance option or did the dual disc give a easier pedal feel.
Old Aug 2, 2013 | 03:08 AM
W37 has two ten inch discs, has more surface area (better performance) and is easier to shift.
Old Aug 2, 2013 | 03:46 AM
507OLDS's Avatar
Yes,the W30 got the M20 also,which is a wide ratio.The common ratio for the 442's that year was 3:23,but the W30's could be found with 3:42's or 3:73's.
ccnclassicoldsmobile
Feb 11, 2013 11:11 AM
Jan 7, 2013 05:52 PM
Oldsmaniac
Jan 16, 2006 05:55 AM
