Yoke leaking?
Old May 28, 2024 | 03:50 PM
Chuxter's Avatar
1970 Cutlass Supreme
Yoke leaking?
Finally got my pan all sealed up. Now it seems I am leaking fluid through the yoke. I have changed the rear seal on the transmission and nothing feels wet all the way back but there is fluid dripping out around the U Joint. It is a turbo 400 transmission out of a 1974 98. Any thoughts or has anyone seen this before?
Old May 28, 2024 | 04:04 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Hows the fluid level? Over full will do this. So will a plugged vent tube.
Old May 28, 2024 | 04:41 PM
OLDSter Ralph's Avatar
If its leaking from inside the yoke, you may need to replace the O-ring on the output shaft (tailshaft).
Old May 28, 2024 | 07:01 PM
Chuxter's Avatar
I'm thinking it's probably the o ring. Will try to get to it this weekend. Will the transmission drain from removing the tail shaft housing?
Old May 28, 2024 | 07:06 PM
Sugar Bear's Avatar
Some fluid will come out but it won't drain the transmission. The more you raise the back of the car the less fluid will come out.
Remember chock the wheels thoroughly if your counting on the rear wheels to hold anything because once the driveshaft is out Park is useless and the car can roll if the rear wheels are on the ground, a drive-on lift or ramps.
tgilligan
Drivetrain/Differentials
Aug 6, 2020 05:33 AM
MrNick
Sep 9, 2018 05:55 PM
ReallyWildStuff
29
Jan 26, 2017 09:28 AM
RustyOlds
Oct 5, 2015 09:19 AM
ddx77
Jun 7, 2010 01:01 PM
