diesel engine manual transmission swap
Old Aug 26, 2023 | 06:29 PM
trapoc's Avatar
Has anyone put a manual transmission behind a 1982 DX 5.7 I'm planning on using an sm465 trans. Any info would be appreciated
Old Aug 27, 2023 | 03:46 AM
bw1339's Avatar
How about something like an AX15?
Old Aug 27, 2023 | 05:46 AM
GM never installed a manual trans behind the Olds diesel, not even in the Chevy truck installations. You will have a few problems here. First is the flywheel. While a 1968-up Olds MT flywheel will bolt to the diesel crank, the diesels used a smaller diameter ring gear to accommodate the geared diesel starter. MT flywheels like this don't exist, so you'll have to have a flywheel custom machined to fit the diesel ring gear. Second is the lack of a pilot bearing recess in the crank. Not a deal breaker, but it requires the crank to be machined (or the use of one of the conversion bearings). Third, I'm not sure there's a BOP bellhousing that accepts the larger bearing retainer on the SM465. People have machined the BOP bellhousing to accommodate this, but the larger opening gets too close to the pivot ball for the clutch fork. A hydraulic throwout bearing rectifies this.
Old Aug 27, 2023 | 07:04 AM
trapoc's Avatar
Joe Padavano Well you do have some knowledge, but a manual trans was installed in the 1979 cutlass with a diesel and i was the owner of one. I have a brand new bop bellhousing and do see the issues. I bought an adapter plate so i could use the chev bellhousing instead. the stock 5.7 dx crank was drilled at the factory and I can provide pictures. not sure why it was drilled though. What I was really looking for is anyone done this before. If someone has then they maybe able too save me some time. Thanks for the info.
Old Aug 27, 2023 | 07:46 AM
You are correct, sorry, I forgot about those. Do you have a flywheel? That's got to be a unicorn
Old Aug 27, 2023 | 12:45 PM
I'm surprised Oldsmobile didn't install a manual transaxle behind a diesel in the FWD Firenza or Cutlass Ciera.
Old Aug 27, 2023 | 01:03 PM
Neither the Firenza nor the Calais were ever offered with a diesel. The Ciera and FWD Ninety Eights only got the V6 diesel and only with automatics. The manual trans in the Ciera was only rarely offered with gas engines.
epinkston
Sep 28, 2018 04:12 PM
JuliusH05@gmail.com
Non-Olds Engines
May 30, 2017 05:59 AM
Chris Schoff
Jun 26, 2013 03:07 AM
slodat
Aug 20, 2010 10:01 AM
njot33
Sep 25, 2009 09:07 AM
