Metric 200 install with a 1962 215 in an F85.
Old Feb 13, 2025 | 07:39 PM
Eff-eighty-five's Avatar
Hi,
Looking for advice from anyone that has gone through this. I have an opportunity to pick up a recently rebuilt metric 200 to replace the Roto 5. It is from a mid 80's V6 Olds so it does have the BOP bell housing. From what I've read there is minimal modification needed to the trans tunnel to get it to work, which is what I wanted. I just have other questions regarding getting everything else connected, shifter/speedo cable/TV cable/driveshaft, etc.
If you have done this, or know of a source (thread) on the subject, I'd greatly appreciate your input.
Thanks!
Old Feb 15, 2025 | 10:12 AM
jmos4's Avatar
Hi,
I could be mistaken but believe the 215 have a unique bellhousing so you might need an adapter.
Regards,
Jim
Old Feb 15, 2025 | 10:45 AM
Originally Posted by jmos4
Hi,
Regards,
Jim
D&D sells that adapter kit, which has the adapter plate and a modified flexplate. Unfortunately the kit requires a Chevy-pattern TH200, not the BOP-pattern.
ripper27
Jul 9, 2018 02:17 PM
HP62
Apr 11, 2018 04:29 PM
grandpa206
Jul 7, 2015 02:46 PM
Wise Performance
Dec 17, 2013 05:35 AM
maybell32
Jul 16, 2006 09:51 PM
