Early shifting 67 400 switch pitch
My transmission is shifting way too early and I'm thinking it has a faulty vacuum modulator. Looking at replacements online I see that some are adjustable with a set screw inside the vacuum port. Have not looked at mine yet, are the stock ones adjustable? What is the best one to buy?
Mine is a switch pitch as well but i had the opposite issue. 2nd to 3rd was shifting at 3K RPM which was to high with 3:90's. After replacement it shift smooth and early. If i manually shift the shift kit is very noticeable and shift on command.
Did you play around any with the adjuster?
No, i was happy with the stock setting under normal driving conditions. If i need it to shift harder the manual shift seems plenty hard enough. There are some vids out there but i think clockwise gives a bit later, harder shifts, whereas counter would do the opposite.
If im just cruising casual im in 3rd gear at about 15/20 MPH with no hard shifts. 3:90 gears so is expected. If i step into it a bit my shift ranges spread out to higher RPMs. What is you shifting conditions? Did it change suddenly to early shift points? When you shift manually does it hold until you manually shift between gears? The vacuum modulator adjustment may be what you need if you want to extend shift points and firmness a little under normal driving conditions.
You want full & constant vacuum established via manifold vacuum only. Could there exist the chance the automatic transmission modulator line is connected to a carburetor ported vacuum source instead of manifold vacuum source? I don't believe a '67 has a TVS or any other emissions nonsense which might interfere so ensure you're direct to a manifold vacuum source.
Tried a new adjustable modulator today with set screw one turn out. Still no change to early shifting. Pulled the governor out and let my transmission man take look at it. He said it had medium to light springs so we removed the spring on one side to see what effect that had. It still shifts early and I ran out of time for today. Had to free up my lift for tomorrow. Tomorrow I'm going to try it with vacuum disconnected from modulator.
Turning the screw in raises the shift points.
Keep in mind, at most you can change shift points 2-4 mph with the modulator adjustment. If you need a bigger change it’s time to start playing with the governor. Before attempting governor modifications, it’s very important to make sure the kickdown solenoid works correctly. Without the kickdown working, the trans will always tend to “short shift” at wot.
Tried it with vacuum disconnected from modulator and it would not shift out of low gear. Went ahead and bottomed set screw out and that helped some. At WOT now it shifts to 3rd at 60 instead of 50. That confirms modulator valve is not stuck and firmness felt pretty good. My next move is to get the B&M governor kit and start playing with weights.
Got a chance to work on the governor again today. Added the 2 lightest springs from the B&M kit but the weights would not fit..go figure. Anyway, I took one of the factory weights and ground 2 grams off of it. Tried it out and bingo, almost exactly what I wanted. Next chance I get I will remove 1 gram from other side and it should be spec on.
