200-4r not shifting
Old Dec 13, 2025 | 07:36 AM
bigbender's Avatar
200-4r not shifting
I have a 1987 Cutlass Supreme with the stock 200-4r transmission. Recently (within the last few months) it has had trouble shifting at ~20-25 mph. To shift i have to run the rpm real high, let off until they drop, and than gas it again. I dont know much about transmission work, but I checked and my transmission fluid level is fine. If anyone else had an issue like this, how did you fix it? Or is this time for me to invest in a better transmission?
Old Dec 13, 2025 | 08:06 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Make sure the TV cable is moving freely, it could be stuck. The governor could also be sticking and causing the late shifting issue.
Old Dec 14, 2025 | 02:17 PM
69CSHC's Avatar
That was my first concern.
And that's my second.
Bigbender, there used to be so much readily available info on adjusting the TV cable 20 years back. Now it's so hard to find.
But this may help.
Post #3 here https://gbodyforum.com/threads/200-4...ustment.17533/
Thanks to DrRansom442 of the g body forum.
I had a 87 442 on the road back then and thanks to the internet I had the TV cable set to performance perfection.
Good Luck !
Old Dec 15, 2025 | 05:32 PM
tkcutlass's Avatar
This might help
Old Dec 15, 2025 | 08:07 PM
bigbender's Avatar
Thanks a lot, my cars currently caked under about half a ft of snow, but once it clears up ill try this out.
1984_Delta88
Jan 28, 2022 12:03 PM
tom54tay
Apr 6, 2021 08:17 PM
maineolds
Dec 3, 2020 08:51 AM
miller6323
Jun 11, 2020 04:54 AM
brown7373
Dec 22, 2014 09:05 AM
