Shift indicator question - Cutlass 76
Hi! I wonder if someone knows where I can buy a new lever on the mechanism for the shift indicator on the speedometer? I have a column shifted car and I accidently broke the lever when I was removing the speedomoter. The metal string is ok but the plastic lever behind the speedometer broke off and I need to replace it.
I have the exact same problem. Looking for that plastic needle.
