68 442 Post coupe swap suggestions.
Old Jul 13, 2023 | 08:27 AM
KCastl03's Avatar
So, my car came with a 4 speed from the factory, currently it has a TH400 mated to a 73 455 in it. I’d like to convert it back to a stick. The only 4 speed parts the car came with are the Z bar, Clutch pedal and a correct bellhousing. Based on what I currently have and what I want to do, what would be the best, but also most budget friendly way to get the car converted back to a manual transmission? Just looking for some cruising and occasional spirited driving not a pro touring car. Thanks in advance.
Old Jul 13, 2023 | 09:45 AM
Your first problem is that the 1973 motor likely does not have the crank drilled for the manual trans pilot bearing. Olds typically did not drill the cranks on motors that came from the factory with automatics. Your second problem is that a 1973 FA block typically does not have the drilled and tapped hole for the z-bar pivot ball. The options for the crank are to either pull the crank and have it machined or use one of the conversion bushings that require shortening of the trans input shaft. If the pivot ball hole is not present, consider using a hydraulic throwout bearing, which also eliminates z-bar interference with headers.
Old Jul 13, 2023 | 10:42 AM
KCastl03's Avatar
thanks for the feedback. Yeah I was already planning on hydraulic clutch and throw out just to eliminate any header clearance issues. From a model of transmission standpoint would an M20 or Tremec 5 speed be the better option you think?
allyolds68's Avatar
As long as you're willing to spend a small fortune there are five and six speed options available. If you want to do some "non 75 mph highway cruising" a Muncie is your best bet. Your rear end will determine whether you want an Muncie M20 or M21.
Old Jul 13, 2023 | 11:03 AM
KCastl03's Avatar
yeah I know silversport has a kit for $5000 before installation so I doubt I’ll go that route. Not planning to daily drive it but some highway driving to a couple of bigger shows might be in the mix. I’m pretty sure the car has the factory 3.42 gears but I’ll double check. Thanks again.
As long as you're willing to spend a small fortune there are a five and six speed options available. If you want to do some "non 75 mph highway cruising" a Muncie is your best bet. Your rear end will determine whether you want an Muncie M20 or M21.
Old Jul 13, 2023 | 11:47 AM
allyolds68's Avatar
I have 3:42's with an M20 with 255/60/15's (27" tire) in my 68 and I love it
Old Jul 13, 2023 | 12:04 PM
I know exactly what you mean, but dang that's not the best way to phrase it.
dan1s
Dec 27, 2023 05:01 AM
KCastl03
Jan 24, 2022 09:42 AM
jordan845
24
Mar 28, 2015 11:47 AM
mmurphy77
Hurst/Olds
Jun 30, 2012 06:14 PM
LoganMiller68
Apr 7, 2012 05:54 PM
